DIY: Rear sway bar advice
Hello all,
I have been reading a lot of threads on rear sway bar mods, but no one talks much on what setting they used, closest, middle, farthest hole. I am going to install my new rear sway bar and wanted to know what everyone thinks is the viewed setting? I was thinking the middle, but then using the 1st setting to mask it stiffer is that more optimal? Advice?
making the sway bar shorter in the rear will result in more oversteer, rear coming out, less results in understeer, feel of front end plowing. do as jeremy suggests and start in the middle and go play to see what you want the car to do. find a track or autocross the car...
