DIY: Grounding kits made simple, step by step guide to making your own!
Old Feb 23, 2018 | 05:04 PM
  #211
Dan G37's Avatar
Dan G37
Originally Posted by RMB5190
Yup! 16/17 Ft. was more than enough for me when I incorporated the throttle bodies. 13 ft. when I didn't.
Just make sure you get the correct gauged connectors with 5/16 IDs
awesome thank you! How does this compared to the stillen grounding kit? Or should it be about the same?
Old Feb 26, 2018 | 10:15 AM
  #212
RMB5190's Avatar
RMB5190
Should be the same. Stillen kit is the same materials + $150 lol
Old Feb 26, 2018 | 12:14 PM
  #213
Baadnewsburr's Avatar
Baadnewsburr
My apologies on getting this up everyone. Here is the way the kit is supposed to be set up. All points are circled and labeled. Blue 'mist' is there to show you how it is ran. I've added some additional connection to my TB and plan to re-do everything this winter in order to clean it up a bit. I'll make a new DIY if one hasn't been posted by then. If anyone has any questions in reference to the pics below - please don't hesitate to ask.
**Not a word on how dirty my bay is**
Connections A-B-C
Closer of pic of Connection C
Connection C leading to Connection D
Location of connection D
Singe wire. Connections E-F
Connections G-H-I
Closeup of Connection H
thanks for posting this with the arrows and highlights, I cant wait to see your DIY
Old Feb 26, 2018 | 01:55 PM
  #214
RMB5190's Avatar
RMB5190
Still tweaking some stuff so I can keep it simple yet hit the main(?) spots
Old Feb 28, 2018 | 05:50 PM
  #215
bloodbruise's Avatar
bloodbruise
Originally Posted by Flakman
I ran multiple cables to the block, but for cosmetic reasons more than anything.
I am also a car audio nut and agree with the big three. However, from what I understand, on the G, running a cable from Battery pos to Alternator output bypasses the car's charging sensor. It senses load and adjusts alternator output accordingly (apparently to save fuel). Therefore, bypassing this by connecting alternator output straight to the battery will keep the system thinking that it only needs to charge at a lower voltage and the battery will not get charged properly under load.
Someone can chime in to correct me if I'm wrong.
Just to throw it out there. I would agree. I wired mine up this way, and let my radio play for about 20-30 min just sitting in the car without the engine running, and my battery died.
Old Mar 5, 2018 | 05:30 PM
  #216
Dan G37's Avatar
Dan G37
For the Guaged connectors what would I need for the 4 AWG terminal guage. Don't I need to add 2 wires into 1 guage connector like the first thread on this DIY?
Old Mar 7, 2018 | 01:10 PM
  #217
RMB5190's Avatar
RMB5190
Sorry should've been more clear - Yes 4AWG for where two wires join but the actual opening (where the screw threads through) should be 5/16.
Example: 8AWG
https://www.genuinedealz.com/catalog...BVCLP-8-516%09
4AWG:
https://www.genuinedealz.com/catalog...6%2FBCLP-4-516
Different gauge size, same hole opening size. Hope that clears it up.
Old Mar 7, 2018 | 01:15 PM
  #218
Dan G37's Avatar
Dan G37
Example: 8AWG
4AWG:
Haha its all good, I figured it out and knew I was an idiot. How much of the wire did you strip off to connect the guage to the wire?
Old Mar 7, 2018 | 01:30 PM
  #219
RMB5190's Avatar
RMB5190
¯\_(ツ)_/¯
Not sure, maybe .5 - 1 ''?
Just cut your shrink wrap long enough to cover any exposed wire and still cover the connector's krimp area.
Old Mar 7, 2018 | 01:55 PM
  #220
Dan G37's Avatar
Dan G37
¯\_(ツ)_/¯
Sounds good thank you
Old Mar 8, 2018 | 11:55 PM
  #221
Dillons VQ37's Avatar
Dillons VQ37
Originally Posted by AZg37
No problem guys!
I'm just now starting to do this type of stuff to my car as I just bought it about 3 months ago. I know this is thread is about 6 years old but great write up man! This helps!
Old Mar 9, 2018 | 08:21 AM
  #222
RMB5190's Avatar
RMB5190
Now that the DIY is fixed (photobucket block) & I've added my photos, a new, separate DIY is hardly necessary given how well this one was done.
Old Mar 12, 2018 | 05:47 PM
  #223
Dan G37's Avatar
Dan G37
Do you twist the two 8 guage wires together where they meet for the 4 guage connector?
Old Mar 13, 2018 | 03:04 PM
  #224
RMB5190's Avatar
RMB5190
I would so that the connection stays solid. I twisted, stuck in, crimped, heat wrapped, electrical taped all my connections; in that order.
Old Mar 14, 2018 | 02:11 PM
  #225
Dan G37's Avatar
Dan G37
Is electrical tape needed? Or would heatshrink just be enough?
