DIY: Grounding kits made simple, step by step guide to making your own!
Old Oct 1, 2018 | 12:01 AM
  #241
Conboss's Avatar
Conboss
Originally Posted by llebcire
Whine in audio? I’d search through the audio forum for advice especially if you have aftermarket components introducing noise.
-Eric
that’s the problem. Nothing aftermarket is causing this! Since I bought the car, there’s been this tiny noise in the audio, and I had thought this would have fixed it. Whatever it may be, I’ll check out that side of the forum and try and figure this out.
Old Oct 20, 2018 | 06:34 AM
  #242
user 83033's Avatar
user 83033
Hi there, after reading a lot of good things that people who have actually used a ground kit on their cars im going to try it out one weekend and see if it helps, i have the 5AT. I was just wondering does the tranny need a ground wire as well?
Old Oct 20, 2018 | 12:07 PM
  #243
hobbs's Avatar
hobbs
See post #234.
Old Oct 20, 2018 | 04:30 PM
  #244
user 83033's Avatar
user 83033
Originally Posted by hobbs
See post #234.
Yeaaa Thats doesnt really answer my question haha
Old Oct 20, 2018 | 07:48 PM
  #245
hobbs's Avatar
hobbs
It actually does; it is a picture of a Voodoo Priest. It's your money, spend it as you wish.
Old Oct 20, 2018 | 07:59 PM
  #246
user 83033's Avatar
user 83033
Ill just stick to the DIY for now then and maybe do one later, So i should dress up like a voodo priest and do a rain dance whislt installing the grounding kit to the positive terminal? 😂😂😂
Old Jan 6, 2019 | 11:47 PM
  #247
Itsjdmyo's Avatar
Itsjdmyo
I just finished my wires using the posting instructions. It's not the prettiest but it'll get the job done. I will report back on feedback once installed.
Old Jan 7, 2019 | 05:48 AM
  #248
jpowersjr2's Avatar
jpowersjr2
6mt or Auto?
Old Jan 7, 2019 | 07:53 AM
  #249
Itsjdmyo's Avatar
Itsjdmyo
Automatic
Old Jan 7, 2019 | 08:06 PM
  #250
Itsjdmyo's Avatar
Itsjdmyo
UPDATE: As others have mentioned, after installing the ground wires, shifting speed has significantly increased. Before, when in DS and manually shifting from 1st to 2nd gear, it would be an estimated 1.5secs to shift but now it's about .5secs. I can't say much about the audio as i don't pay attention much to it but my goal was to increase the shifting speed. While i understand it won't make the car any faster, it definitely makes for a better driving experience. There are still some extra wires, so i'll probably ground both throttle bodies this weekend.
Old Jan 11, 2019 | 08:32 PM
  #251
Itsjdmyo's Avatar
Itsjdmyo
So my car has been sitting for the past 3 days, went to go start it this morning and it wouldn't start. Interior lights will flicker a bit and there will be a slight crank but it wouldn't turn over.
After a jump from my wife's car, it started back up...anyone else experienced this problem after installing a grounding kit?
I went through all the wires again to make sure they were all tightened. After a check of the battery voltage, it will hover around 13v after the car warms up...thoughts?
Old Jan 11, 2019 | 09:14 PM
  #252
RMB5190's Avatar
RMB5190
It's been mentioned somewhere in this thread, but sometimes the connection to the negative terminal acts as a parasitic drain on the battery. Disconnecting it from there seems to solve the issue. I have mine attached to it and have not ran into the issue.
Old Jan 11, 2019 | 09:45 PM
  #253
jpowersjr2's Avatar
jpowersjr2
That's the main reason I haven't done one. That and I have a 6MT so benefits are much less.
Old Jan 11, 2019 | 10:15 PM
  #254
RMB5190's Avatar
RMB5190
You can get those sweet audio gains
I can understand where some might say it's snake oil but I actually installed this the moment I got the car home and ran it for over 20k miles. I didn't really experience the car without it. Decided to experiment and took it off for a week and the difference was quite noticeable. The transmission is lazy but without this it's downright comatose. Even in 'DS' mode the downshifts were very slow and lethargic. Sudden aggressive throttle inputs would actually result in a very noticeable delay where it seemed like the car outright refused to downshift. I remember counting in that week 3-4 separate times where I noticed the transmission behave differently than it did when the grounding kit was installed when the throttle input was practically identical.
While it was installed, the transmission was no DCT but at least it would pick up the pace and be predictable when I asked it to and the downshifts in 'DS' were noticeably snappier.
As a 6MT owner, I highly recommend you pick up that bell brace that's been the hot topic as of late. As I stated in 4DRZ's review of it, that brace does for traction and power delivery what a thicker swaybar does for bodyroll and eliminating understeer (AWD) and oversteer (RWD).
Old Jan 11, 2019 | 10:20 PM
  #255
jpowersjr2's Avatar
jpowersjr2
I'm definitely a believer in it. I'm interested to see my how my audio sounds after my Tesla screen install.
Yes sir, I was on the Group Buy
