ZahyMatar's '12 A54 G37x Sedan
Finally got everything scheduled with LightWerkz to get my headlights done! Car is getting dropped off on March 8th, picking her up on March 10th. Quad 90mm Diode Dynamics HD Switchback Halos, 3" STI-R Clear Lens, matte black housings, gloss black shrouds, Phillips X-Treme Ultinon LED Turn Signals, and Osram CBI 5500K bulbs. It's gonna be a good time.
List of parts awaiting install:
-Stance XR1 true-type coilovers w/ 13/8k Swift springs
-SPL rear toe/camber arms w/ eccentric lockout kit
-SPC 73005 Front Upper Control Arms
-Akebono BBK w/ Z1 slotted rotors, Hawk HPS 5.0 pads, Z1 SS lines, Motul fluid
-Emblemless grille w/ outer edges painted VR
-JDM tail lights with Phillips LED turn signal bulbs
-Fast Intentions 2.5in exhaust w/ 18in resonators and coupe mufflers
You helped me out quite a bit! I contacted Stance directly and they even recommend 13/8k for the AWD sedan, so I think I made the right choice.
On that note, would you be interested in a pair of Phillips LED X-Treme Ultinon turn signals? I'm going to be purchasing some from Japan, $50 a pair. Let me know! They're some of the best LED turn signal bulbs on the market.
and what the issues were with standard LED's in that bulb location. I'll probably pass this round but I greatly appreciate the offer!
You'll be seeing quite a bit more this August
Sweet! Looking forward seeing the grill most of all.
I'm still stuck trying to find someone local (NJ/NY/PA) who will make an emblemless grille for me.
Looking forward to that.
