New Tires/Brakes 2010 G37S Coupe
The rear toe arm has one end that slides in a slot to adjust toe. When the Tech adjusts toe, he will unbolt at the slotted end, move that end into proper position then tighten the bolt. Your car's arm is at the end of the slot. The slot can be widened a bit to increase adjustment range.
Your rear thrust angle is perfect but it could use another half-degree or so of toe-in for stability. Until the toe bar slot is widened, the Tech can't fix it. Your front toe-in could be reduced so your tires will last longer.
Thanks, got it. I'll ask him to reduce the front toe in and see what he says about widening the slot. Are these adjustments (camber and toe) independent of each other, or is camber also affected when you adjust toe?
On a previous response on this thread referring to brake pad dust you mentioned "If you hate cleaning your wheels, you'll have to go with some type of ceramic pad." Can you elaborate on cleaning your wheels? Clean your wheels when you wash your car or take the wheels off and really get the dust out of your rotors etc.? (I detail my car at least every 2 weeks with exceptions).
Total Toe as per specs in the front now.
From 0.11 to 0.04 degrees total toe in the front now. Not sure it's subliminal but steering wheel felt a bit smoother. I think the "spc toe bolt template.pdf" attachment points to the "slot" being talked about earlier. In my case I'd have to purchase the camber link and toe bolt to bring the rear within specs since total toe rear adjustment has been maxed out.
Fezzik
Jan 14, 2011 11:05 AM
