NOOB HERE with 2010 g37s
Old Sep 15, 2015 | 10:24 PM
cyberone28's Avatar
cyberone28
hello all, i didn't know i had to do alignment on my tires every now and then, and because of that my tire wore out on one side (right front tire)
also when i brake my steering wheel vibrate, i know is the rotor that needs to be changed, went to local shops and they want to charge me an eye of my face... so im planning to be a DIY for the sake of my wallet...
my question are..
1.... ive been reading a lot on here about the potenza RE760 275/35/19 ---245/40/19 i have stock rims any other recommendation as far as tires? (i live in houston by the way, so no snow here..)
2... where should i buy my rotors and brake pads?
3... my REAR/FRONT LEFT tires are about 70% tread life should i go ahead and change them all or just 2?
thanks in advance... 2010 G37s COUPE
Old Sep 15, 2015 | 10:28 PM
Ricio1991's Avatar
Ricio1991
Congrats! Rock auto for your brakes, centric has good brakes and are affordable!
Old Sep 15, 2015 | 10:42 PM
cyberone28's Avatar
cyberone28
where can i get them? can you point me in the right direction thanks!!!
Old Sep 15, 2015 | 10:57 PM
Ricio1991's Avatar
Ricio1991
First on list
Rotors for the brake package
rockauto.com
Old Sep 15, 2015 | 10:59 PM
Ricio1991's Avatar
Ricio1991
Part Numbers
Centric 12042101
Old Sep 15, 2015 | 11:04 PM
Edit~Riccio beat me to it, and nice screenshots too!
RockAuto Parts Catalog
Enter Infiniti, your year, then scroll to Brake/Wheel hub, then Rotor
You then scroll through rotors and find a front Centric for a 355mm rotor, if you want a step up then find the Centric Premium 355mm rotor. Do the same for the rear sets.
For Pads go through the catalog and select Brake Pad, in the menu scroll down to Centric Posi Quiet Ceramic if you want a pad similar to OEM, if you want a pad w/ better bite, but more dust the Stoptech Street Pads are a good choice but require a aggressive bed-in.
Also site vendor KNSbrakes.com has good pkg deals.
Be sure to do a full brake fluid flush when you do your brakes.
Old Sep 15, 2015 | 11:05 PM
Ricio1991's Avatar
Ricio1991
Brake pads Centric
Front brake pads:CENTRIC 30113460
Rear brake pads: CENTRIC 30113470
Old Sep 15, 2015 | 11:16 PM
cyberone28's Avatar
cyberone28
WOHA!!! loving this site already!!! thanks a bunch!!
Old Sep 15, 2015 | 11:24 PM
cyberone28's Avatar
cyberone28
one more thing, what about the tires? are the 760s good? im not a crazy driver but once in a blue moon i like to hit that throttle
Old Sep 15, 2015 | 11:25 PM
Ricio1991's Avatar
Ricio1991
Thanks lol love to help out I knew you always a point to the right direction!
Old Sep 16, 2015 | 12:29 AM
cyberone28's Avatar
cyberone28
one last thing,
the front rotors are the 355 mm? and the rear are the 350 mm??
FRONT... More Information for CENTRIC 12042100
REAR.... More Information for CENTRIC 12042101
is this right?
Old Sep 16, 2015 | 12:37 AM
Ricio1991's Avatar
Ricio1991
Believe so rock auto should be spot on
Old Sep 16, 2015 | 08:24 AM
Yep, 355mm front 350m rear rotor set.
And sthe 760s are decent tires, but when it comes time to replace there are better choices for the same price or less. Michelin Pilot Super Sports are the gold standard.
Toyo T1Sports are a good performer for a good price.
Old Sep 17, 2015 | 10:03 PM
cyberone28's Avatar
cyberone28
ok guys first of all thanks for all your info!! GREATLY APPRECIATED!
I just went to a local FIRESTONE shop, and got me my 2 set of tires potenza re760 .... 275/35/19 rear and 245/40/19 front with ( lifetime alignments $189 value) , for $921.50 they are running a weekend special -$50 per tire!! so i saved $200..
CANT BEAT THAT..
now tot he point.. im about to make the purchase on my rotors and brake pads, please let me know if this are the right one...
REAR ROTORS... https://www.rockauto.com/catalog/mor...id=611&jpid=13
FRONT ROTORS... https://www.rockauto.com/catalog/mor...id=611&jpid=24
FRONT BRAKE PADS... https://www.rockauto.com/catalog/mor...id=704&jpid=98
REAR BRAKE PADS... https://www.rockauto.com/catalog/mor...id=704&jpid=78
please reply ASAP if the parts are correct or if you have a better combination please let me know so i can order them..
also what do you guys think of the duralast from Autozone?
Once again THANK YOU A MILLION!!!
Old Sep 17, 2015 | 11:41 PM
Ricio1991's Avatar
Ricio1991
Seems like your on the right track there with the parts , and personally I wouldn't use duralast parts on my infiniti other than the battery because I do have a duralast gold with a 5 year warranty but replacement parts on my opinion are a no go but each their own maybe someone else can give their opinion on them here
