My logic here was that my summer set up was 19x9.5 +25 so I figured a 19x9 +20 would bring it very very close
That offset will depend heavily on how low you plan on dropping the G on coils. I know you're not going to slam it but even going low you might be a little sunk with the +35 but I would rather have that especially on the track then try and run more camber than you want
Hello all,
Latest thoughts on potential squared setup below. Looking to drop 08 G37s coupe on Eibach Pro Kit
Wheels: xxr 521 18x10 all around offset +25
Tires: 265/35/18
Any thoughts on rubbing etc.? Will this clear the big brakes? Camber Kits?
Think this should work due to this aka inspiration
quick pics new wheels - MY350Z.COM Forums
Thanks
Tires: 265/35/18
Thanks
New set up option:
'10 sedan X
20x9.5 +20 all around
245/35 tire
Swift springs
Thoughts on if this will work? Per Chinky's post on his winter set up, this looks like it might be real close
Miro 110 wheels btw.. Surprised I havent seen these on any other set ups
'10 sedan X
245/35 tire
Swift springs
Hello all,
Tires: 265/35/18
As far as clearing the brakes, you'd have to verify w/ the vendor, send this template to them if they can't verify
https://conceptzperformance.com/imag...nttemplate.pdf
Thanks
Tires: 265/35/18
Thanks
https://www.myg37.com/forums/brakes-...ml#post3815735
Unless you plan to drop further and run more camber those are going to poke pretty good. ChinkyChoys 9.5 +25 setup is running higher camber (at least from the pics posted), another 5mm further out would be really pushing it IMO. A 9.5 +35 would be a much easier fit w/ spec camber.
picture Lt8ches' coupe but the wheels 15mm further out w/ slightly stretched 245s, may take a bit more camber to tuck
8.5 +35s on 245/45/18 will work fine for your sedan as long as you aren't planning on a BBK upgrade. You'd have to check w/ the vendor if you plan on bigger brakes in the future.
