Help SPC Front Camber Kit Rattle
Morning update, everyone.
I spoke with Jeff@SPC this morning regarding the camber kits. Thanks to G_Thang, Jeff will be sending me a set of G35 front camber arms as they are physically a tad shorter from the pivot point out to the ball joint than the G37.
He explained that the reason the G37 parts he designed are extended is to provide further positive camber adjustment. I gave him feedback regarding this to the affect of, if one were to need that much positive adjustability, the tire would be physically touching the plastic of the fenderwell.
I'll provide any more info as I'm fed it.
Good deal. Thanks for fitting the G35 arms. I know we'll all be happier once this is done. I think the new design will only be camber and not caster adjustable since thats where most of the height came from. Thanks again John.
I also spoke with Jeff this am to make sure he got my email, pics and measurements. He got them today as he has been out sick for few days.
He is sending me a set of arms too so that he has perspective on someone with only Eibach drop and then from Finagle69 on coilover. He also wants pictures of the top of the arm showing how much camber adjustment was needed to correct (and therefore how much extra may be uneccesary). He would also need before and after camber measurements. All this for the reasons Finagle69 describes below. BTW, he does not have immediate access to a G37 hence all the requests for data / pictures.
He also asked if we would help spread the word that SPC will send out bumpstops to anyone that wants to hang in there until this is resolved. The bumpstops will go on the strut which means you have to take the strut out, but it is an option. I suggested that he give Andy @ HPAuto or Eddy @ THMotorworks the instructions on how to get the bumpstops so they could post for everyone. I thought that would come across as more "official".
He said he would do that.
He said he would do that. Morning update, everyone.
I am on Eibach and was green as well. I did dial in -0.5 degree on caster when I put the arm in just to bring it closer to nominal, but it is not needed. And my Eibach settled in at about -1.5" vs. -1.2" and still in spec.
I asked that specific question on the temp solution of bumpstops and he said they would be sent to anyone that asked.
I did not ask that specific question on the permanent solution. I was more focused on making sure he had what he needed from me. I was operating under the assumption that new arms would have to be provided at no charge. Sorry I was not more specific. Maybe Andy or Eddy can find that out and post as well along with the how to get bumpstop information.
Another point I noticed after installation: The top of the threaded rod of the ball joint protrudes above the nut (the one that TQs to 120lb-ft) a good 3/8" or so after fully TQ'd. If this is shortened, that gains just that much more travel distance. I'll relay that on to Jeff.
I didn't change caster on mine, but I think I'd like to give a little negative caster a try. Should help lighten up steering a bit and give a little more bite in corners.
Edit. Now that i think about it, mine hit both the leading edge of the arm and the top of the threaded rod... I'll find the pic I have of it.
Double Edit. removed
Triple Edit. I found the pic. See attached.
Update:
Email from Jeff @ SPC
"Users that are having up stop travel issues can contact SPC and we will send them a set of bump stop spacers, no charge.
The spacers will be for the short term. If the spacers do not resolve the issue then the customer may contact us directly and we will work with them one-on-one to resolve their issue. In the meantime SPC is working diligently to correct the issue. We appreciate their patience in this matter. "
I just received by bump stops and Im sitting here scratching my head
I received 20 metal L shaped tabs with a pole punched thru and 2 tabs pointing down??? WTF is this. I thought it was a polyurethane bump stop we were being sent??? Anyone else get these in the mail? The P/N on the bag says 721208.
