Need help!! Diy turn as tail diode dynamics
Old Aug 15, 2015 | 11:22 AM
  #61
cmackin's Avatar
cmackin
I also have the hyperblinking issue with brake depressed. If anyone has any ideas please let me know. It worked normally for a while, but after a month or so the passenger side hyperblinks with brake.
Old Aug 15, 2015 | 01:46 PM
  #62
jman09's Avatar
jman09
i'd check your connections for the passenger side. if that looks good, i'd look at replacing the resistor on that side as the next step.
Old Aug 15, 2015 | 03:26 PM
  #63
JC-RH's Avatar
JC-RH
Originally Posted by JC-RH
I installed it exactly like this on my 2011 sedan. Same color wiring. Tried the hazards and turn signals, and everything worked great. When I started driving, I noticed that I would get hyper blinking if I had the turn signal AND the brake pressed. As soon as I would release the brake, the regular speed blinking came back. Happens on both sides. Any suggestions???
Maybe I didn't squeeze the red splice things hard enough. I'll post a pic later of my wiring. Both sides work are acting exactly the same.
Old Aug 15, 2015 | 09:18 PM
  #64
JC-RH's Avatar
JC-RH
Bumppppp
Old Aug 17, 2015 | 02:27 PM
  #65
JC-RH's Avatar
JC-RH
I fixed it earlier today. I had done everything correct except for one of the resistor ends. I had tapped it into the green with yellow stripe wire (brake) instead of the solid green (turn) wire. I switched it over, and it works awesome now.
Thanks Diode!
Old Aug 18, 2015 | 12:38 PM
  #66
2GoRNot2G's Avatar
2GoRNot2G
I just received my module from Diode Dynamics yesterday. I will try to get it installed this weekend and post up some pics next week.
Old Nov 2, 2015 | 08:25 AM
  #67
PGg35s's Avatar
PGg35s
Is the plug and play version for the sedan ready?
Old Nov 2, 2015 | 09:27 AM
  #68
Diode Dynamics's Avatar
Diode Dynamics
We are still waiting on the factory connectors to arrive
A thread will be posted when they are available
Thank you,
Nick C.
Old Dec 13, 2015 | 04:23 PM
  #69
mrig37's Avatar
mrig37
@nick from diode I just placed an order yesterday for my DIY for 2013 g37 sedan. But didn't add the resistors because I didn't read abut the hyper blink till after. Is they're anyway I can either add them on or just cancel my order and really do it
Old Dec 13, 2015 | 09:20 PM
  #70
Arrogant's Avatar
Arrogant
I just placed an order for mine too. I figured I might as well do this because I am going to be removing the back bumper to replace the bracket that holds the license plate led's since it rusted to ****. I have a lot of work to do this week.
Old Dec 13, 2015 | 10:58 PM
  #71
RxRyanM's Avatar
RxRyanM
DD shipping is pretty darn fast, so you should probably call in the morning to make sure they can combine them so you don't have to place another order/get hit with another shipping charge.
......the only thing this requires is unhooking the carpet in the trunk and peeling it back. No bumper removal needed.
Old Dec 13, 2015 | 11:59 PM
  #72
Arrogant's Avatar
Arrogant
That is my point. You have to do that in order to remove the bumper so might as well do this while I have peeled back the carpet.
Old Dec 14, 2015 | 11:46 AM
  #73
Diode Dynamics
All PM's have been replied to!
Thanks,
Nick C.
Old Dec 14, 2015 | 05:55 PM
  #74
bigmike35nj's Avatar
bigmike35nj
I just replaced mine this past weekend. Can't believe that piece is close to 60 bucks.
Old Dec 15, 2015 | 10:08 AM
  #75
ocie's Avatar
ocie
I'm having this happen to me on the passenger side tail light. I checked my splices and crimps, still have the hyper blinking.
Thanks Diode!
I could see the metal splice through the solid green wire, so I gotta take another look today after work.
