Need help!! Diy turn as tail diode dynamics
Old Jun 30, 2015 | 10:25 PM
JSolo's Avatar
JSolo
Just say no!!!!!
@37, something with your hook up is incorrect. Can you take some pics? Being able to see actual connections will be helpful.
Verify resistors are an open by measuring their resistance with an ohm meter.
Old Jul 1, 2015 | 01:30 PM
Diode Dynamics's Avatar
Diode Dynamics
We will have a plug and play version for the G37 Sedans soon! Just waiting on the factory connectors to arrive
Nick C.
Old Jul 1, 2015 | 02:19 PM
jman09's Avatar
jman09
Originally Posted by Thirty_Seven
What resistors did you use and how did you wire them? I went from the yellow wire in the kit to a ground and nothing changed, then I tried turn signal power > ground and still got nothing.
i am using the same value resistors you are. resistor goes from the turn signal wire (before the tail-as-turn DIY kit) and then to ground wire.
Old Jul 1, 2015 | 02:46 PM
jman09's Avatar
jman09
Originally Posted by Ipp391
Thank you for bringing up the subject because I didn't even kno that DD sold these!! I've been wanted to do this for a while but the forum member that was making his homemade kit wanted like $75.. I couldn't justify spending that much. But for $15 shipped, done deal.
actually $10 shipped if you PM DD for a free shipping code, assuming you live in the US.
Old Jul 1, 2015 | 10:47 PM
Thirty_Seven's Avatar
Thirty_Seven
Ground wire being the solid black one right?
Old Jul 2, 2015 | 08:49 AM
jman09's Avatar
jman09
yes it was the black wire for my coupe.
Old Jul 3, 2015 | 06:08 AM
takeapieandrun's Avatar
takeapieandrun
Wow, this is an awesome, sleek mod. I have LED turn signals with wired resistors but they aren't as bright as OEM and this is just much more modern looking.
Old Jul 3, 2015 | 01:29 PM
Diode Dynamics
For those who may be wondering, the OEM LED array is plenty bright for daytime use. (Hence why they are OEM brake lights as well)
Great time to pickup the kit, we are running a 4th of July sale: "JULY4" for 10% off
Nick C.
Old Jul 3, 2015 | 02:01 PM
JSolo's Avatar
JSolo
Just say no!!!!!
Nick, I have interest in this product (for a sedan) but would like to retain the stock turn signal bulb. That is, have both the led ring and stock bulb flash when a turn or hazard request is initiated. Appears for the coupe the resistors come prewired. Is it possible to have a variation of this module where the stock bulb is used rather than resistors. Should just be a matter of changing wiring slightly on the oe connectors. In fact, cost should be less as resistors are not needed then.
Old Jul 3, 2015 | 02:10 PM
jman09's Avatar
jman09
unless you really need the convenience of the OEM connectors in this kit, you can just use the standard DIY kit and wire the stock turn signal bulb to the output wire of the kit to accomplish what you are looking to do.
Old Jul 3, 2015 | 02:13 PM
JSolo's Avatar
JSolo
Just say no!!!!!
^^Not so much the convenience factor. I just don't want to cut into factory wiring unless absolutely necessary. I suppose if I go that route, all connections will be soldered and sealed with heatshrink tubing.
Old Jul 3, 2015 | 02:18 PM
jman09's Avatar
jman09
that's what i did instead of using the crimp connectors that came with the kit. plenty of wire and room to work with.
Old Jul 6, 2015 | 01:14 PM
Diode Dynamics
We will have the plug and play Sedan kit available very soon
If you don't want to wait, the DIY kit is just $10 and $10 additional for a set of resistors
Nick C.
Old Jul 7, 2015 | 05:20 PM
  #29
tony76's Avatar
tony76
I bought the tail as turn for my sedan who knows how to install it with the load resister is there a video.
Old Jul 9, 2015 | 01:17 AM
  #30
nishfish871's Avatar
nishfish871
DD, make a thread in the sedan section when the pnp kit is made so we all can order!
