Review Lowered '10 G37x (AWD) Coupe
Old May 17, 2015 | 07:27 PM
  #31
VQHAY's Avatar
VQHAY
OP are you still on oem struts/shocks?
Old May 27, 2015 | 09:23 PM
  #32
Akashsaroya's Avatar
Akashsaroya
Need information on lowering the g37x on eibach
I just bought eibach pro kit for my g37x 2012 coupe. What is the best camber kit and toe bolts? Is that all I will need for my setup to be good? What about the oem struts? do they go bad by lowering it or what?
Old May 27, 2015 | 09:49 PM
  #33
The life of the OEM dampers will be affected by lowering springs but how quick varies greatly from vehicle to vehicle.
If you have a dremel tool you can get the rear bolt kits rather than the toe bolt & arm for about $65 (you need 2 kits for the rear wheels) the front kit is over $350 so I'd at least get the rear set and see how it aligns and take it from there, if you're on a tight budget, if not I'd get the complete kit.
Here's the rear camber & toe bolt kit
SPC Performance Camber/Toe Cam Bolt Kit; Pair, Reqr's 1 per Wheel INFINITI G35
Old May 27, 2015 | 09:55 PM
  #34
Akashsaroya
Which complete kit would you recommend?
Old May 27, 2015 | 10:28 PM
  #35
Akashsaroya
And where do I buy them from?
Old May 28, 2015 | 12:58 AM
  #36
Here you go~
Combo Packages 2 Rear Camber Arms w/ Toe Bolts + 2 Front Adjustable A-Arms (Complete set for whole car front and rear) INFINITI G37
Old May 28, 2015 | 02:01 PM
  #37
Akashsaroya
Read some really bad reviews about that site. I'm just going to buy them individual from tunerzstore or importpartspro. Thank you
Old May 28, 2015 | 07:22 PM
  #38
They've always been great w/ me, used them many times, but
G's
Nov 5, 2023 12:01 PM
G37xhibeet
Nov 15, 2016 09:29 AM
timc00k
Sep 5, 2015 05:12 PM
Dillybar12
Aug 17, 2015 04:52 PM
350zrunnin12s
Aug 9, 2015 09:55 PM
