245 275 tires
245 275 tires
Does anyone run 245/40/19 275/35/19 set up? Can i get a little info if its better than the the size tire the car came with or just better looking. pics would be very helpful
I'm running 255/40/19 and 285/35/19 with a stock setup. I feel like the ride is smoother and i grip better due to the increase in surface area of the tire in contact with the road. However, the downsize is that the tires are wider so they are a little soft in the sidewalls so that introduces a bit of "roll" on sharp turns. As far as looks....no contest in my opinion. Looking at it from the rear with the 285's is a view to behold. lol.
I'm thinking of going 245s and 275s as well. I think TVPostSound did the same deal with the set up your looking for at this thread.
https://www.myg37.com/forums/g37-cou...spacers-2.html
I'm thinking of getting wider tires, but I think with the drop that I have I might be SOL.
My setup is:
I run 19 x 8.5 35 and 19 x 9.5 40 Avant Garde M310 wheels with...
245/40/19 and 275/35/19 Hankook V12 tires.
I'm doing these numbers off the top of my head but i'm pretty sure thats what it all is.
RUnning on stock suspension (no drop) and I love the look, feel, drive, etc... Best mod for the car.
I'll check later tonight when I get home to make sure those numbers are correct.
The 245/40/19 & 275/35/19 size would be a perfect size to upgrade to if you are looking to go a little wider.
Here are some numbers/specs when comparing the stock tire size to the new tire sizes:
OEM SIZE: 225/45/19
Overall Diameter - 26.97 inches
Sidewall Height - 3.99 inches
Revs per Mile - 771.16/mi
NEW SIZE: 245/40/19
Overall Diameter - 26.72 inches
Sidewall Height - 3.86 inches
Revs per Mile - 778.54/mi
OEM SIZE: 245/40/19
NEW SIZE: 275/35/19
Overall Diameter - 26.58 inches
Sidewall Height - 3.79 inches
Revs per Mile - 782.58/mi
Hope that helps!
OP, you won't need spacers unless you want your OEM wheels sit closer to the fenders.
-Frank
OEM SIZE: 225/45/19
NEW SIZE: 245/40/19
OEM SIZE: 245/40/19
NEW SIZE: 275/35/19
Hope that helps!
-Frank
mmnjtwa
Sep 7, 2015 02:27 PM
