The OFFICIAL "I have a wheel offset / tire fitment question!" thread
Old Mar 3, 2016 | 03:26 PM
  #1186
WhtaBeautXs's Avatar
WhtaBeautXs
Bad part about that GTR setup is you're going to have to run a stretch tire in back (which means you'll also have to run stretch in front) so keeping your rolling diameter under 1% for your AWD compatibility gets a bit trickier. You could run something like a 225/40 255/35 combo. You can make it work but you'll have to be creative. You could also run the same 255s all around, member Ryne has a setup similar, with staggered wheels but the same tire size all around on his AWD and appears to have no issues, so there's a couple ways you can go.
G/L and look forward to pics.
I like the 255/35 all around. Think that'll work? Could member Ryne chime in if possible?
Old Mar 3, 2016 | 11:35 PM
  #1187
Here's his build thread, there's a lot there but you should find the info you need, and shoot him a PM if you have specific ???
https://www.myg37.com/forums/build-t...g37-coupe.html
His is a coupe so he'll have more fender clearance, you may have to run some extra camber, but maybe he can give you further details.
Old Mar 4, 2016 | 10:56 AM
  #1188
Quigs1591's Avatar
Quigs1591
my case: 2012 G37xS Sedan AWD
Looking to buy wheels very very very soon. My main question is, at what wheel or tire width will I start rubbing either in the front or rear? I am dropping it with the eibach 6399.140 G35x sedan setup this weekend. End result I would like a concaved wheel such as the Niche Misano M116 that I have been considering but noticed a massive difference between the 20x9 and 20x10 concave(ness). Clearly I know I can fit the 20x9 but wondering if 20x10 will fit as long as I keep the tire 255/35/20. Also I want close to stock camber, I dont want excessive wear on my tires and therefore I will not consider tucking the tires with negative camber.
Old Mar 4, 2016 | 11:15 AM
  #1189
the93owner's Avatar
the93owner
Depending on the offset, you should be fine with 20x10 on a 255 tire. Someone fit a 19x10 +40 on a 255 on all 4 corners with minimal camber and I don't believe it rubs. See post below.
With camber under -2 degrees I don't believe you'll see any excessive wear.
https://www.myg37.com/forums/brakes-...ml#post3998096
Old Mar 4, 2016 | 11:17 AM
  #1190
Quigs1591's Avatar
Quigs1591
offset of the Niche wheels i'm looking at are 40mm offset. any idea for that offset? stock for my car is 45mm front and 50mm rear
Old Mar 4, 2016 | 11:20 AM
  #1191
the93owner's Avatar
the93owner
offset of the Niche wheels i'm looking at are 35mm offset. any idea for that offset?
With the extra 5mm sticking out you may start to get some rubbing, but I'm not sure. See if you can search around and find someone with a similar setup. I imagine you can fix that with just a hair more camber, nothing that will affect your tire wear subsantially.
Old Mar 4, 2016 | 11:23 AM
  #1192
Quigs1591's Avatar
Quigs1591
I'm sorry the wheels i'm looking at have 40mm offset for 20x10, the 20x9 are 35mm.
Old Mar 4, 2016 | 11:34 AM
  #1193
the93owner's Avatar
the93owner
That should be fine. Those are pretty common specs for the sedan.
Old Mar 4, 2016 | 12:08 PM
  #1194
Quigs1591's Avatar
Quigs1591
So to just make things easier. I should deal with the less concaved wheel with the 20x9 35mm offset and run a 245/35/20 tire to keep (out of stock range) camber and wheel rub out of the picture?
Old Mar 4, 2016 | 12:09 PM
  #1195
Quigs1591's Avatar
Quigs1591
Thank you for your help. 20x10 is what I think I will do.
Old Mar 5, 2016 | 09:20 PM
  #1196
chartkor's Avatar
chartkor
Hey new here
I have 2011 G37X on stock 17. Planning to upgrade to 18s for the summer. What kind of offset do I want to run for nice flush factory look for 8s or 8.5? Probably gonna run 235/40 or 245/40 if 8.5
Car will probably never be lowered since I live in a frozen wasteland and outside of city.
Cheers
Old Mar 6, 2016 | 12:45 AM
  #1197
OfficialG's Avatar
OfficialG
I usually run Hankook v12s for my stretching needs but I can't find 225/35/20 size anywhere for some reason....
My wheels are 20" 9.5 -11 and 10.5+12. I am on air and running some negative camber.
I would like to know what tire brands in sizes 225/35 and 245/35 have a similar stretch and lifespan as the hankooks in those same sizes.
Thanks.
Old Mar 6, 2016 | 07:57 AM
  #1198
Originally Posted by chartkor
Hey new here
Cheers
Look for 8.5 +30 to +35 for a nice fit at the fender and 245/45/18 is the tire size you should run to keep your diameter closer to OEM size, the 245/40 will be almost an inch shorter and almost 4% off from OEM.
Old Mar 6, 2016 | 02:41 PM
  #1199
Upscale Speed's Avatar
Upscale Speed
I have 245/35/20 mounted on 20x8.5 +24 in the front will my new BBK fit?
Rear I have 285/30/20 mounted on 20x10.5 +45. I assume they fit in the rear easily. Please advise.
Old Mar 6, 2016 | 05:51 PM
  #1200
Depends on the spoke depth and if you're running a deep lip type wheel.
Typically that offset on an 8.5 should clear but there's exceptions for sure.
Here's templates you can use just to be sure
https://www.myg37.com/forums/brakes-...templates.html
