Official Low Offset/Hellaflush Thread
Old Nov 14, 2016 | 02:17 PM
  #2146
b-drizzy's Avatar
b-drizzy
rears don't let you sit on the floor huh ?lol
Old Nov 14, 2016 | 02:59 PM
  #2147
SmoothJamaican's Avatar
SmoothJamaican
(4) FF1 19x8.5 / 19x9.5 +35 5x114.3 Flow Form - OPEN BOX need help!! Can i run 245 front and 275 rear?
Old Nov 15, 2016 | 05:29 PM
  #2148
b-drizzy's Avatar
b-drizzy
Wrong thread bro
that's some meaty tires u need this is for stretch tires and clearance for slam G's
but
those wheels should fit with those sizes though
Old Nov 16, 2016 | 09:17 PM
  #2149
Broski28's Avatar
Broski28
Does anyone know if a coupe can run a 20x9.5+2 and a 20x11+6?
I have a new 2017 Q60 coming and I got offered a great deal on a set of wheels but I have a feeling they might be too aggressive. I heard the new coupe is fairly similar to the old on in regards to fitments.
Thanks in advanced
Old Nov 17, 2016 | 12:51 PM
  #2150
b-drizzy's Avatar
b-drizzy
might rub a bit but should be ok I think
slight camber if anything
Old Nov 29, 2016 | 07:04 PM
  #2151
hotdawwgman's Avatar
hotdawwgman
Need some help choosing tire size.
I am doing 20x10.5 +25 Square on my G37 Coupe. What tire size you would you recommend. I am at a -1.9 Front Camber and a -2.7 Camber in the rear... Rear I think will be fine but the front I was thinking -2.5..
This is how low my car is currently
Old Nov 30, 2016 | 12:49 AM
  #2152
infamouslkv's Avatar
infamouslkv
Do you like the look of stretched tires or not? 255/35 if you like stretch tires look, 285/30 for meatier tire look.
Old Nov 30, 2016 | 10:08 AM
  #2153
VenomGT9's Avatar
VenomGT9
285 all day, with -2.5 you'll be fine
Old Nov 30, 2016 | 01:47 PM
  #2154
hotdawwgman
Great to hear! I will most likely go stretched. Roll My Front fenders right?
Old Dec 7, 2016 | 02:40 PM
  #2155
b-drizzy's Avatar
b-drizzy
i like how outcast did your front..
nice to be the first one rocking, saw when you posted it on IG
Old Dec 7, 2016 | 08:30 PM
  #2156
hotdawwgman
Thank you. I have better shot of the car I need to post
Old Dec 8, 2016 | 12:39 AM
  #2157
Hdinh94092's Avatar
Hdinh94092
My current set up is 20x10 +30 and 20x11 +30. Front is fine I'm running 235/35/20 but I'm about to go up a size so it will be 245/35/20. It's the rear I'm pretty much need help on. 20x11 +30 with Pirelli zero 285/30/20. It's pretty wide and barely stretched but I'm rubbing pretty much on every dip or bumps on highway. I didn't shave bumper. Racket yet but I think I will go down to 255/30/20. Is that too much stretch?
I want to go lower a bit in the rear that's why. Right now I can stick a finger in between the fender and tire.
Old Dec 8, 2016 | 08:35 AM
  #2158
VenomGT9's Avatar
VenomGT9
get a slight pull or an aggressive re-roll of the fender and you'll be good...255 will be too much of a stretch
also you need to trim the bracket regardless, even a little more camber will help
Old Dec 8, 2016 | 06:48 PM
  #2159
hotdawwgman
Old Dec 9, 2016 | 09:29 AM
  #2160
VenomGT9's Avatar
VenomGT9
rear fit is a beaut
