Official Low Offset/Hellaflush Thread
Old Mar 31, 2016 | 11:45 AM
  #2086
b-drizzy's Avatar
b-drizzy
You should be fine in the front without a camber kit unless you go wider in fronts, I was running 9.5+12 too and I think was at -2 camber
this was me when I was on stance true coils
ITs really up too the owner how they want the car to look at
I have my front just little lower then rear
Originally Posted by nosser
Me? Mine are Megan... rears have a lot of room still but don't have my camber kits installed yet. Fronts were pretty much maxed. I just raised them so I'm at 25.75" fender to ground, but I may go to around 26" all around. Think I read that's where most people sit.
Old Apr 3, 2016 | 12:49 AM
  #2087
evil-G-nius's Avatar
evil-G-nius
just got my wheels and coilovers installed this past weekend they are
9.5/10.5 +22
225/35 and 245/35 19
I am looking at the same wheels for my coupe! They look great!
Old Apr 19, 2016 | 12:38 PM
  #2088
J.Tilley's Avatar
J.Tilley
New coupe owner checking in! I wouldn't consider my taste in wheel fitment as the "hellaflush" standard... but from what I've been reading, it seems like the "go-to" offset range for these cars is +35 to +40 on a 8.5/10 wide wheel. However, I was leaning more towards a 9.5/11 setup with a +20 and +28 respectively. I don't mind running a little bit of camber, but I'd like to keep it under -2.5. Am I in the right ballpark, or should I take this to the "offset question thread"? lol Thanks in advance!
Old Apr 19, 2016 | 12:43 PM
  #2089
VenomGT9's Avatar
VenomGT9
Technically no this isn't the right thread as this is more for posting your setup w/ pics for others to reference. However, it is on topic. I think if you run a 11in wide rear you may need around -3deg of camber depending on which offset you go with. If you find something in the low 30s you may be fine but anything lower might cause some rubbing...in addition to your tire choices.
Old Jun 15, 2016 | 04:27 PM
  #2090
Broski28's Avatar
Broski28
To the guys running 20x10.5+25 all around on Coupes:
How much camber is needed in the front and back? I don't mind slightly out of spec but I am trying to get a better understand of it before I get new wheels.
Also is it possible to run a 265/30/20 tire instead of the fairly common 255/30?
Old Jun 20, 2016 | 01:40 PM
  #2091
b-drizzy's Avatar
b-drizzy
You should be fine in the rear but front youll need to camber least -2 or so to clear fenders
don't run 265/30 up front try a 245/25 or 35 series
but then it also depends how low you are ? or are you on stock suspension ?
Old Jun 21, 2016 | 01:01 PM
  #2092
Broski28's Avatar
Broski28
I am trying to go as wide of a tire as possible so a 245 doesn't work for me. I was reading a couple people ran 265/30 up front with "minimal" camber so I was trying to get an idea of just how much.
I would be on coilovers
Old Jun 21, 2016 | 03:44 PM
  #2093
That Dude's Avatar
That Dude
It may be possible but I would assume those people weren't that low (meaning they have at least a finger wheel gap) and are definitely rubbing on dips and turns. A 255/35 tire is probably the max you can have up front for the setup you want. 245/35 up front will all but ensure no rubbing at most heights.
Old Jun 24, 2016 | 10:45 AM
  #2094
Broski28's Avatar
Broski28
Thanks man. I'll probably just stick with 255 then. My buddy used to run that set up with no issues, I was just hoping to get a little more meaty lol
Old Jun 28, 2016 | 12:41 AM
  #2095
etphonehome22's Avatar
etphonehome22
i have an 08 g37 coupe, anyone have a general minimum offsets you can run? looking for new wheels and i want to have some guidelines. I am on airlift V2 and want to run 19s, that's where i'm starting and obviously have a long way to go so anything will help.
Old Jun 28, 2016 | 09:06 AM
  #2096
VenomGT9's Avatar
VenomGT9
Mid to upper 20s if you want to play it safe...assuming you're not going to run crazy width/camber
Old Jun 28, 2016 | 12:22 PM
  #2097
b-drizzy's Avatar
b-drizzy
When your on air anything is safe lol ..
Old Jun 28, 2016 | 01:17 PM
  #2098
Are you going w/ wheels that you can custom offset or a set that has a few set offsets to choose from. If it's the second option what offsets are listed in the Infiniti bolt pattern?
Old Jun 28, 2016 | 03:21 PM
  #2099
etphonehome22
right now im looking at vishnus that are -2 offset all around and 10.5 in the front and 11.5 in the rear and have serious doubts if they can fit even on air. and im not oposed to custom, but not going to go down that road till this winter.
Old Jun 28, 2016 | 05:33 PM
  #2100
VenomGT9's Avatar
VenomGT9
I think you'll have more issues fitting the fronts than the rears...both will need some crazy camber though
