Official Low Offset/Hellaflush Thread
Old Jul 18, 2017 | 01:25 PM
  #2206
That Dude's Avatar
That Dude
Originally Posted by xmajd92
hey guys! So I'm lowered on D2 Coilovers and I got some Volk GT-S wheels. Rears are 19x10.5+17 with 275/35 tires. I do not have a camber kit. What would you guys suggest I do here? Pull/roll fenders or should I just add a bit of negative camber here? Check out the pics.
If you want to keep those tires then you definitely need to run some camber and do some trimming.
I personally would swap them out to a 255/35/19 and lower a little more, that would help a lot.
Old Jul 18, 2017 | 01:29 PM
  #2207
xmajd92's Avatar
xmajd92
Yeah I was afraid of reading that answer lol. I don't want too much camber so I'll just put my Weds Sports back on and resell them lol.
Trimmed the bracket. Pulled the fenders a bit. Still rubs on deep dips and extra weight on the back. Other than that it's fine. I don't like the stretched tire look nor do I want anymore camber added. Not a "stance" kind of guy. Plus I don't wanna have to keep aligning the car everytime I switch to my 18" Weds Sports for when I hit the track. Decided I'm not selling these anytime soon.
Old Jul 19, 2017 | 11:25 AM
  #2208
b-drizzy's Avatar
b-drizzy
awesome glad it work out for you, within time the fenders will naturally pull little bit more with all the random bumps on the road ..
Old Aug 3, 2017 | 01:01 AM
  #2209
Datez's Avatar
Datez
Hey you guys, I have my G coupe lowered on the Eibach springs and I don't have a camber kit. My camber is -1.79 and -1.68 in the rear. I found a set of wheels I'd like that are 19x9.5 and 19x10.5 +25. Will these wheels fit at the specs I'm at? If not, what would it require me to do? What would be the tires I'd need to run?
Old Aug 3, 2017 | 06:55 AM
  #2210
douby77's Avatar
douby77
Bro you can probably fit 22s in there wit no problem lol. Ok maybe not 22s but with eibach you can do a lot and never rub
Old Aug 3, 2017 | 07:07 AM
  #2211
douby77's Avatar
douby77
Official Low Offset/Hellaflush Thread-photo4294966414.jpg tien in the rear eibach in the front Official Low Offset/Hellaflush Thread-photo902.jpg
Old Aug 29, 2017 | 05:49 AM
  #2212
Tones11's Avatar
Tones11
On my Sedan I've been rocking zero'd out camber in the rear and 2' up front for a while now and am curious how much camber one can run and still get decent tire wear as long as toe is good?
Of course zero camber is what someone would want to get perfectly even tire wear but what I'm asking is how much camber can I run and still get "acceptable" tire wear? At what negative degree does it go off the deep end?
I want to start running some negative camber to get a more stanced flush VIP look.
I was thinking 4 degrees in the rear and 3.5 up front? Nothing crazy but a wider look.
Currently running:
20x9x10
245/35/20
285/30/20
Thoughts?
Old Aug 29, 2017 | 02:56 PM
  #2213
b-drizzy's Avatar
b-drizzy
is that going on a coupe or sedan ?
  #2214
b-drizzy's Avatar
b-drizzy
Old Aug 29, 2017 | 11:03 PM
  #2215
Tones11's Avatar
Tones11
Sedan. How much camber are you running?
Old Aug 30, 2017 | 11:19 AM
  #2216
b-drizzy's Avatar
b-drizzy
I'am running -6 in rear and -3 front, I'm low enough where my key fob don't go under my car lol
19x10.5 +22 rear 245/35
19x9.5 +12 front 225/35
it all depends how low you want to be, running camber only makes sense if your riding low, you don't want to add camber if your not low, and depends how wide you want to run your setup all that comes into play..
Old Sep 20, 2017 | 08:31 PM
  #2217
Awdnigg4's Avatar
Awdnigg4
My figment numbers
This is my g37x 2009 coupe. It's got square (well not really because of the spacers) setup. Front +38 f1r f35 20x10 255/35/20 with 15mm spacers. Rear is the same setup except the spacers are 20mm. So technically the offset is 23mm in front and 18mm in rear. It's also got eibach lowering springs on it. Nothing rubs. Sits perfectly with that big booty. Hope I can help some one with these numbers.
Old Jan 3, 2018 | 12:08 PM
  #2218
2011-G's Avatar
2011-G
Here is a new challenge
2011 G37 sedan upgraded to BBK
Wheel sizes as below
20X9 (F) et 15
20X11.5 (R) et 20
I know I will be running a lot of negative camber and might have to roll the fenders but what tire size do you guys think I can get for the front and rear- I would like to fit the widest tire possible - I am ordering my coilovers suspension soon so want to know my tire size options in advance.
And if anyone has ever ran a similar setup, let me see it
Old Jan 4, 2018 | 12:18 PM
  #2219
b-drizzy's Avatar
b-drizzy
are you going to run stretch tires ?
Old Jan 4, 2018 | 12:36 PM
  #2220
2011-G's Avatar
2011-G
I'm trying not to run stretch tires - But I don't think I have another option.
Maybe I should just sell the rear set and get something less aggressive?
What is the widest tire sizes I can get away with without hitting any of the control arms and fender liners lol
P.S - I love the stance on your car. It looks perfect to me but I don't think without bags mine can look that good
