Official Low Offset/Hellaflush Thread
Old Dec 26, 2014 | 12:11 PM
  #1936
b-drizzy's Avatar
b-drizzy
are you on a coupe or sedan ? lol
Old Dec 28, 2014 | 01:59 PM
  #1937
deathtrap's Avatar
deathtrap
Im new to g37 fitment and apologize if this has been answered before. What is needed to fit the following on a 2013 g37s coupe? The car is slammed on BC coilovers.
Front: 20x10 +25 - 225/35/20
Rear: 20x11 + 28 - 255/35/20
Old Dec 29, 2014 | 07:02 PM
  #1938
Learn2bartend's Avatar
Learn2bartend
Hey guys! New to the community. Well, might be on Wednesday. Going to look at an '11 37s Vert. So hopefully I get it!
Wanted to know what offsets this car takes? Been trying to research but didnt find anything specific.
I think I want to keep 19's. I may want to put lowering springs on it. I want it to be flush with nice meaty tires. I HATE that stretched, cambered, "Stanced" look. Personal opinion. I want my tires to hook nicely.
With that in mind....any help would be great. Private message me if you have any ideas please.
Thank you =)
Old Dec 30, 2014 | 02:00 PM
  #1939
b-drizzy's Avatar
b-drizzy
Just get camber arms and make sure to realignment after you install if not your going to have crazy camber.. The back you might run maybe about -4 or less but the toe will be off and front defenetly need camber arms
Old Jan 3, 2015 | 07:34 PM
  #1940
Unique1231's Avatar
Unique1231
offset fitting
I have a 2 inch pull in the rear, current run a 20×10.5 +15 I want to know if I could run a 20×10.5 +5 rear +10 in the front? Running a 255-30 on it now. Anyone have this setup??
Old Jan 11, 2015 | 03:07 PM
  #1941
TheGanglyGoon's Avatar
TheGanglyGoon
I have nothing more to say.
Old Jan 12, 2015 | 12:20 AM
  #1942
evil-G-nius's Avatar
evil-G-nius
^^^Because you are speechless or you hate it?
Old Jan 12, 2015 | 12:56 AM
  #1943
mj_39's Avatar
mj_39
That's his own car if memory serves me right lol
Old Jan 12, 2015 | 02:30 AM
  #1944
evil-G-nius
AH! LoL
Old Jan 21, 2015 | 02:31 PM
  #1945
stevo4756's Avatar
stevo4756
What are those rim specs?
Eat through tires with that camber (btw what is your camber)?
Found a great deal on Volk GT-C previously on a 350Z for $1700 with tires.
20X9.5 +22 20X10.5 +22 on Toyo Proxes 4 255/30 295/30
According to what I have found the rear rim will sit about .5" out of the fender (sound right?) ? Front flush?
Since I'm on stock height (08 G37S Coupe) would this set up look funky till I get the car on a SMALL drop? (Ohio roads suck, snow sucks) It might be a while till I can afford to properly drop it (springs, adjustable shocks?, camber / toe kit)...
I hope not to sound like a noob, but is it possible to have the rims machined to get that offset to + 25-27 (take 3mm-5mm off the back of the wheel?) I plan on calling Volk, but stuck at work right now...
Any direction is greatly appreciated!
Old Jan 21, 2015 | 04:09 PM
  #1946
b-drizzy's Avatar
b-drizzy
not worth it, just find another set that fits you, honestly it would be just too much hastle to just do that..
Old Jan 21, 2015 | 04:30 PM
  #1947
Ryne's Avatar
Ryne
The Steering Wheel Guy
Those specs are way too aggressive to run on stock ride height. The wheels and tires would be way past the fenders, even if you managed to machine the offset back a few mm. A small drop would probably still not cut it with those tire sizes. You would definitely need to stretch tires, probably for the front and rear, run a good amount of negative camber, and lower aggressively.
Old Jan 22, 2015 | 10:09 PM
  #1948
stevo4756's Avatar
stevo4756
I plan on lowering soon.
Does it matter that these GT-C are the face 2 (curved spoke)
So lets say I slap on some 265/35 on the rear and drop it 1"?
Coil-overs or springs ? Tien Street basis coilovers any good? (max drop in rear 1.3")
How much camber do you think I will have to run? (performance decrease if extreme?)
I love the GT-C and since they don't make them anymore I want to make it work. Hell who wouldn't?!
Tien basis coilover highlights:
• Steel Construction
• Twin Tube internal construction
• Larger piston diameter for strut type front and rear (22mm)
• Non-welded ZT coated Adjustment Tube
• 1-piece Aluminum Spring Seat with Delrin Thrust Washer
Spring Rates (FT~RR):
- 9KG~8KG
- 504LB~448LB
Old Jan 23, 2015 | 09:53 AM
  #1949
Diego@Vossen's Avatar
Diego@Vossen
I run 20x10 +10 285/25/20 & 20x11 +38 305/25/20.
Old Jan 24, 2015 | 07:37 PM
  #1950
stevo4756's Avatar
stevo4756
Do you have pictures of your pull? Who did it?
