Up coming intake manifold testing.
Old May 21, 2015 | 11:28 AM
  #61
ANMVQ's Avatar
ANMVQ
If your going to port it use a dremel but but go easy the plastic will heat up, Then go over it by hand with sand paper. You know I have a ported M370 and a non ported M370 I would sell . possibly the Z1 also
Old May 21, 2015 | 04:24 PM
  #62
stevo4756's Avatar
stevo4756
Yeah I noticed one of your listings. I thought about buying the z1, but would rather spend the money on sway bars at this point in time. Maybe down the road when I decide to port / polish Tbs and lower plenum...
BTW what would one expect to pay to port/polish throttle bodys and lower plenum?
Thanks
Old May 22, 2015 | 08:41 AM
  #63
ANMVQ's Avatar
ANMVQ
Thanks
Its about $200
Old May 26, 2015 | 08:40 AM
  #64
ANMVQ's Avatar
ANMVQ
My other lower has been delivered to Scott for porting on Friday
Old Jun 1, 2015 | 11:10 AM
  #65
ANMVQ's Avatar
ANMVQ
Got the lower from Scott and man it looks great! Installed yesterday and should have some driving notes this week. No dyno this weekend, Will have to be on the 13th. ;/
Attached Thumbnails Up coming intake manifold testing.-scotts-lower-port.jpg   Up coming intake manifold testing.-scotts-lower-port2.jpg   Up coming intake manifold testing.-scotts-lower-port3.jpg   Up coming intake manifold testing.-scotts-lower-port-closeup2.jpg   Up coming intake manifold testing.-scotts-lower-port-closeup4.jpg
Old Jun 1, 2015 | 07:23 PM
  #66
RadioFlyer's Avatar
RadioFlyer
That looks great! Do you have any idea of how much material was taken off?
Old Jun 2, 2015 | 12:52 AM
  #67
Synolimit's Avatar
Synolimit
Idk if I'm aloud to say here cause I'm not a vender (all transactions were done on another forum admins) but I removed an *** load! His two halves with the casting marks were crazy off! Along with 100% removal of both bumps in each runner it was quite a lot. I could of removed more however but without the heads and upper it's hard to do or I could remove to much and cause a lip at the heads. Also you don't want to remove to much in the middle, which you could, because you'll have a small opening coming off the upper mani, have it open real big, then neck back down going into the heads. I'm not sure an hour glass shape would help flow.
Old Jul 2, 2015 | 12:28 PM
  #68
Jeff Wharton's Avatar
Jeff Wharton
Any update?
Old Jul 5, 2015 | 09:08 AM
  #69
ANMVQ's Avatar
ANMVQ
Oh wow man sorry guys was updating another one , Car made great power 302 WHP and 240 WHTRQ( Heart breaker) dyno, Also ran 13.5 @105 MPH at the track. I switched software also to ECUTEK.
Old Feb 29, 2016 | 06:44 AM
  #70
Mattlorentzoe's Avatar
Mattlorentzoe
What are the chances you know of a diy to swap the lower out? I've looked everywhere!
HELP!
superjoey
31
Mar 22, 2023 11:56 PM
Mattlorentzoe
Aug 21, 2015 05:09 PM
RoyalG37
Aug 19, 2015 03:36 PM
