New Motordyne Shockwave E370
Old Jun 15, 2012 | 08:32 PM
  #121
MaDMaXX's Avatar
MaDMaXX
Yeah, i know, sorry
Old Jun 17, 2012 | 01:17 AM
  #122
NeverBoneStock's Avatar
NeverBoneStock
Just installed this thing and fawk it's sick ... Couple of things though .... I had to remove my rear GT - Spec bracing . "bummer " Also , did any one notice that the y-pipe on the passenger side rattles against the frame and the driver side has more than enough clearance ??? I had to wrap it with header wrap so there will be no noise .. I also have the art pipes and boy it's loud when u get on it .. There is some rasp though .. Will post pics , video and review ..
Old Jun 17, 2012 | 01:32 AM
  #123
WARAT's Avatar
WARAT
Do you think the rasp is that bad? I have art pipes too and to me its not that bad at all. But then again everybody is different.
Old Jun 17, 2012 | 01:38 AM
  #124
pdxcruiser's Avatar
pdxcruiser
LOVE this exhaust! Been driving around with it now for a day... the sound is a-m-a-z-i-n-g. My car is new and entirely stock except for the E370 and it growls.
I'm having the same problem with the rattling as you. It seems to stop though after the car's been warmed up for a bit. Strange.
Old Jun 17, 2012 | 02:21 AM
  #125
I removed the rear GTSpec rear brace as well (the straight one) to install the exhaust. However after installation I was able to put it back on without interference. I had to remove the cross brace of the 6 point rear brace but I'm pretty sure that I can modify the brace by cutting a slot in the middle so it doesn't rub the clamps on the mid pipes.
Your Y pipe situation sounds odd - the only place my Y is anywhere close to touching anything is on the transmission cross member on both sides. It probably within 1/2" to 3/4" or so but doesn't touch at all. This is with OEM cats.
Old Jun 17, 2012 | 02:40 AM
  #126
NeverBoneStock
It's a different kind of rasp ... It's really weird ... When u get on it with art pipes it's like almost a boom of rasp and goes away .. It's very tolerable ...
Old Jun 17, 2012 | 02:41 AM
  #127
NeverBoneStock
I had to remove my crass brace as well .. Maybe some washers will fix it .. Going to post pics tomorrow ..
Old Jun 17, 2012 | 02:43 AM
  #128
NeverBoneStock
So you have art pipes and the exhaust ?? If so than u must hear the same thing as me .. Its not the typical rasp .. I actually like it ..
Old Jun 17, 2012 | 02:44 AM
  #129
NeverBoneStock
I believe u and I have the same issue .. I need to get under your car ..
Old Jun 17, 2012 | 02:45 AM
  #130
NeverBoneStock
Art pipes have a kinda of buzzing rattle to them that annoyed me .. I wrapped them in header wrap and the noise is gone .. There is none ... Simple fix for the guys that have the
Same issue ..
Old Jun 17, 2012 | 03:09 AM
  #131
NeverBoneStock
Also going to retune the car .. Seems like I have lost some go.. Hopefully a new tune will fix that ???????
Old Jun 17, 2012 | 03:15 AM
  #132
MaDMaXX's Avatar
MaDMaXX
Interesting thing about the result of wrapping the ART pipes, very interesting.
Old Jun 17, 2012 | 03:35 AM
  #133
Staples's Avatar
Staples
You may have lost a little low end torque with the new exhaust. Minor tune changes will get all that lost power back.
Old Jun 17, 2012 | 09:06 AM
  #134
WARAT's Avatar
WARAT
Weird, I'm not experiencing any rattling with the art pipes. As far as rasp, yes its not the annoying kind of rasp. I'm hoping once carbon build up accumulates it will tune it out which I don't or barely hear in the first place.
+1 what staples said. Pretty much with running any type of exhaust/tp combo will lose some "go" low end torque which I was discussing with BB. I expected this result that's why I'm getting the intake manifold then uprev tune.
Old Jun 17, 2012 | 09:17 AM
  #135
I had Berk HFC with my Invidia before the change. I was going to go with ART pipes a little later so I removed the HFC to sell them and put stock cats back on for now. I feel a very noticeable positive difference in low end torque. Also it is plenty loud enough for me (don't you love the way it yells at you under heavy throttle from 4K-5K?) so I may skip the ART pipes altogether. I don't need it any louder and I can skip the rasp and low end loss.
I haven't driven my car much in the week that it's been installed but when I do I truly love it.
