New Motordyne Shockwave E370
Old Jun 18, 2012 | 12:10 AM
  #151
MaDMaXX's Avatar
MaDMaXX
Yes, yes it would, and there i was stuck underneath the backend of my car with the diff off replacing the bushings
Old Jun 18, 2012 | 08:32 PM
  #152
P Casey's Avatar
P Casey
anyone have any numbers yet?
Old Jun 19, 2012 | 02:13 PM
  #153
NeverBoneStock's Avatar
NeverBoneStock
Mini update .. The exhaust is starting to break in and the rasp is gone .. It's also starting to quite down a bit .. Can't wait to see what this thins sounds like after a 1000 miles .. Also , it does hang low .. I'm going to raise the car up about 2 inches tonight. Have scraped a few times .. Other than that ..... It's awesome !!!
Old Jun 19, 2012 | 02:49 PM
  #154
MaDMaXX's Avatar
MaDMaXX
That sounds great
I believe you can adjust the mid pipes so its higher, this is known as a high exhaust usually. Check your center resonator is the right way up
Old Jun 19, 2012 | 02:57 PM
  #155
mason721's Avatar
mason721
it has started to quiet down a bit and the rasp, even with berk test pipes (non resonated), the rasp has lessened. I have the same issue someone else indicated where their passenger side Y-pipe hits the tranny.
I was able to raise the rear section up by rotating the mid-pipes, and it came up about 2-3 inches. When the FI RHFCs come in, I'll be getting some header wrap and wrapping the right side of the Y-pipe
Old Jun 19, 2012 | 04:07 PM
  #156
WARAT's Avatar
WARAT
Finally got a chance today to raise the right side up as well.
Old Jun 19, 2012 | 04:26 PM
  #157
NeverBoneStock
Originally Posted by MaDMaXX
That sounds great
With the center muffler does the motordyne logo face up or down .. I have mine facing down
Old Jun 19, 2012 | 04:42 PM
  #158
NeverBoneStock
I have that problem and so does another member ... Have u tried to call Tony ??
Old Jun 19, 2012 | 05:43 PM
  #159
Logic tells me that the logo should be facing downward were it can be seen so that's how I mounted it. However I'd have also presumed that the stamped Motordyne Engineering logo on the Helmholtz canisters should be right side up on both sides but that's not the case. The resonator is symmetrical with the exception of the inlet flange being slightly angled up or down a few degrees dependent on which side is mounted facing up or down. I believe this is to position the mid pipes in a slightly upward direction of exit rather than parallel to the ground. I believe (can't remember) that this is achieved with the logo facing downward.
Old Jun 19, 2012 | 05:44 PM
  #160
datboiroy's Avatar
datboiroy
Does anyone have an XL Motordyne shirt that they are willing to trade with me? I got a Large.
Old Jun 19, 2012 | 06:11 PM
  #161
NeverBoneStock
Can someone call and confirm if the logo should be facing up or down on the center muffler ??? They don't like talking to me ..
Old Jun 19, 2012 | 06:15 PM
  #162
Lose weight till it fits fatass.
Old Jun 19, 2012 | 06:46 PM
  #163
GET_SOME's Avatar
GET_SOME
lmao we all got size large. im a 2xl minimum. and yes i origionally had the logo puinted up at yhe car and the exhaust almost hit the ground. i flipped the muffler and was able to adjust the midpipes so they sat tight against the car.
Old Jun 19, 2012 | 07:21 PM
  #164
I got an XL. Because I spoke directly to Tony and Mariela and I asked. I wanted XXL but it's the biggest they had. It works.
Old Jun 19, 2012 | 08:08 PM
  #165
pdxcruiser's Avatar
pdxcruiser
I exchanged emails with tony. He's sending me a spacer because "some engines sit more forward". Mneh. I wrapped it in header tape and the knocking be gone...
