Help SERVICE ISSUE - Stillen Long Pipe Air Intake
Old Mar 2, 2011 | 12:54 PM
Bigbodyg's Avatar
Bigbodyg
Exclamation SERVICE ISSUE - Stillen Long Pipe Air Intake
hi guys
I just had my SERVICE ENGINE SOON light come on (no performance issues). I had my dual STILLEN LONG PIPE Air intake (THIS ONE) on for almost a year now. Nothing has changed
SO they took the car in - scanned it and said its mis-firing , Mass airflow sensor issue. They also said they did a little "fix" with an added little pipe (i gotta see this) - so they will now RE-LEARN the computer and see if the error code comes back up. But if it does - its too bad cause of my intake.
ANYONE ELSE HAVE THIS ISSUE! its costing me $200 after 2 tests
I am picking it up soon and getting the error codes to post here as well.
Old Mar 2, 2011 | 12:58 PM
ONEighty's Avatar
ONEighty
It comes back on, get a MAF sensor cleaner, remove your MAF sensors, spray em down and put them back in once the liquid dries.
Old Mar 2, 2011 | 01:08 PM
Bigbodyg's Avatar
Bigbodyg
180custom - thanks so much! I assume the MAF is right where the intake is connect to on the engine - correct?
Old Mar 2, 2011 | 01:14 PM
ANMVQ's Avatar
ANMVQ
Had the same thing with my Maxiam.( Nismo CAI) Removed the MAF bought some clearner at local part store clean+dried put back in no issues.
Old Mar 2, 2011 | 01:38 PM
Bigbodyg's Avatar
Bigbodyg
Is there a DYI on this? Am i spraying the MAF sensor (which i slid into the new air intake) or the actually part on the car? sorry i just don't wanna screw this up any more.
Old Mar 2, 2011 | 01:42 PM
Bigbodyg's Avatar
Bigbodyg
I contacted STILLEN - they send me this:
NEW INTAKE CHECK ENGINE LIGHT FIX
If you’ve installed a new intake kit and soon afterwards the check engine light comes on the mass air flow sensor (MAF) may be dirty or there may be a vacuum leak at one of the couplers.
1. Make sure all of the worm clamps are tight.
2. Disconnect the battery.
3. Remove the MAF sensor.
4. Clean the sensor with electronics cleaner or 90% rubbing alcohol.
5. Allow the MAF sensor to dry.
6. Reinstall the MAF sensor.
7. Reconnect the battery.
8. If the check engine light is still on, you may need to have it reset by a shop or the dealer.
Note: In extreme cases you may need to clean the K & N filter as it was over oiled. When you re-oil the filter, be sure to not over oil it.
Old Mar 2, 2011 | 07:57 PM
chuckie311's Avatar
chuckie311
Drop A Gear and Disappear
cleanthe MAF and see if you still get the light
Old Mar 2, 2011 | 08:03 PM
Bigbodyg's Avatar
Bigbodyg
Well the car is awesome! problem was a cut in one of the vacuum lines off the side of the intake (they replaced it for free - since they had one). Also i paid them to re-program the computer to the new air/flow mixture which the Stillen intake is bringing in. All is good now 401/Dixie Infiniti in Mississauga - BIG THUMBS UP!
Old Mar 2, 2011 | 08:17 PM
DeamonG37s's Avatar
DeamonG37s
Nice glad they fixed it! I'm in Brampton this spring we should go for a cruise!!!!
dak5305psu
Oct 5, 2016 09:34 PM
Sway_NV
Sep 10, 2015 01:51 AM
Gunit37xsedan
Aug 18, 2015 12:06 AM
reigle9
Aug 6, 2015 02:45 PM
Jeebus
Aug 1, 2015 10:26 PM
