A Day at JWT
Old May 28, 2008 | 08:37 AM
  #46
KAHBOOM's Avatar
KAHBOOM
Super Moderator of Pwnage
Originally Posted by nestle_!9
i think you are pertaining to the bypass valve that AEM released ,, for what i heard ,, you actually will lose power with this valve,, so in the end , its like you just have a short ram ,, anybody correct me if im wrong
I guess it depends on how much power you lose. If Injen produces the claimed 14 hp and the bypass valve only saps 5 hp, you still have quite a bit of net gain over a short ram which produces maybe 1 or 2 hp if that.
I hear that most bypass valves only lose about 2 or 3 hp though.
The other downside is that I think you have to cut into the tube to install it. Injen should build one ready built w/ bypass valve.
Old May 28, 2008 | 11:08 AM
  #47
TBreise's Avatar
TBreise
Originally Posted by KAHBOOM
I guess it depends on how much poer you lose. If injen produces the claimed 145 hp and the bypass valve only saps 5 hp, you still have quite a bit of net gain over a short ram which produces maybe 1 or 2 hp if that.
The other downside is that I thinkn you have to cut into the tube to install it. Injen should build one ready built w/ bypass valve.
Are you saying that injen claims their CIA system will add 145hp???
Old May 28, 2008 | 11:47 AM
  #48
MaxToTheG37's Avatar
MaxToTheG37
Super Moderator w/ Boost
^ thats a typo bro... he meant 14hp
Old May 28, 2008 | 11:51 AM
  #49
]\[ /-\ ]\/['s Avatar
look like stillen shortys
Old May 28, 2008 | 04:54 PM
  #50
KAHBOOM's Avatar
KAHBOOM
fixed
145 hp and I would risk the hydrolock LOL!
Old May 28, 2008 | 05:15 PM
  #51
DetroitG37Joe's Avatar
DetroitG37Joe
No not the AEM's bypass valve.. Im talkin about this simple cover that keep water that splashes onto the intake by chance by repelling it thereby further decreasing the chances of it sucking up water.
Hydro-Shields: Durable polyester uniform micron openings with an embedded hydrophobic water repellent process
http://injen.com/docs/products/listing.asp?pcc=ac
Check it out. The Injen is pretty sweeta and to be honest i dont mind just not driving in rain or driving carefully in it and avoiding puddles as long as I have the hydro-shield...
Question: If installing the Injen requires bumper removal - does that mean that changing/cleaning toe cone filters will also require bumper removal????? or is it just the installation?
faze2988
Oct 7, 2015 12:05 AM
LLBj5
Sep 30, 2015 02:57 PM
MrRiv
Sep 29, 2015 04:59 PM
