Battery issue, car won't turn on and shuts off
Old Feb 15, 2018 | 05:32 PM
sho423's Avatar
sho423
I've been having issues with my car, it is a 2013 with 58k miles on it. Sometimes when I try to turn my car on after work it wont turn on. It won't sense that the key is in the car and the speedometer won't light up or anything. Then I would get out and get back in and it starts like normal. And I look at my miles gauge and it is reset to 0. This has happened to me like 3 times over the past 6 months. Then today when I went to go get my oil changed, the tech who was going to do it put my car in reverse and the car turned off while it was in reverse. He went to go get me and I went inside of it and it turned on right away. Any one know what the issue can be? My battery is like 3 months old. I have an extended factory warranty, will the dealership fix the issue for free?
Old Feb 16, 2018 | 05:33 AM
Baadnewsburr's Avatar
Baadnewsburr
Check the battery terminals..it may be loose...years ago sometime after changing my battery I had similar symptoms to what you describe... after going over too many pot holes my negative battery terminal kept coming loose...not falling off or anything but just losing enough contact that I needed to carry a 10mm socket to crank it tight every now and then... I think the metal on the connecting wire was stretched or the post on the new battery was a hair smaller than the old one....
Old Feb 19, 2018 | 01:12 PM
terribleone's Avatar
terribleone
^ my negative terminal is like this too
Old Feb 19, 2018 | 06:17 PM
slartibartfast's Avatar
slartibartfast
In the good old days, you'd hammer a piece of wire or a small nail between the post and clamp to take up any slack.
Old Apr 30, 2018 | 08:25 PM
Archangele's Avatar
Archangele
I have both a 2014 Q60S (new name for G37S) and a 2004 Nissan 350Z. For what ever reason
Nissan and Infiniti use this amazingly stupid, over sized steel negative terminal.
The only fix I found that works and keeps working is to first cut off that original
piece of junk and replace it with one of those old style lead ones. You just strip back
the wire, coat it with dielectric grease, clamp the wire on the new terminal, then attach the
whole thing to the battery. problem solved.
Those old style lead terminals won't corrode and they will clamp on the battery terminal
like an aligator.
Old Jul 30, 2019 | 02:46 PM
Surfnazi's Avatar
Surfnazi
Check grounding straps and that battery has water in cells if low refill with distilled water
Quiver
Jun 9, 2021 10:17 PM
Broseph
Nov 30, 2020 01:49 PM
armino41
Mar 30, 2016 01:25 PM
Krebo
32
Mar 4, 2012 11:08 PM
