P006a
I need help with this DTC P006a
Hi, how are you all? I have a G37 sedan. The engine and transmission were replaced with those from a Q50 3.7. Everything works perfectly, super smooth, with no strange codes. But I have a problem that's driving me crazy. I have a code P006A. I have some aftermarket installations. I replaced the MAFs with OEM ones, they're quite expensive. I checked for air leaks. I don't hear any hissing. I cleaned the throttle bodies.Relearning idling with a scanner. Everything is immaculate. But I'm only getting that code p006A correlation between MAF and MAP. I'm getting a value. MAP at idle between 30 and 40 kPa and MAF between 2 and 3 g/s each MAF sensor. At cruise I'm getting between 88 and 90 and a few kpa on the map and like 10 or 15 g/s for each MAF if I remember correctly. I've investigated and the MAF values are fine. And the MAPs too, I think. Please, someone help me. The car goes into limp mode. I have long-term fuel adjustments between -8 and -11, and the short-term adjustments vary between 6 and 0. Sometimes it depends on how much I accelerate. I don't understand what's going on. Can someone help me? I only have that code.
Last edited by TempoVQ; Sep 11, 2025 at 11:44 PM. Reason: Try to get them to help me
drizzy315
30
Dec 21, 2021 07:53 PM
SLOWG37xS
Jun 28, 2020 12:37 PM
