Coolant hose replacement help needed
Old Nov 24, 2022 | 11:37 PM
si_driver's Avatar
si_driver
On the driver's side of the engine, just under the ignition coil of the 6th cylinder, there is a short maybe 3" coolant hose.
Has anyone replaced this piece? Any tips how to get my hands there and put a new hose on?
It's #18 on the diagram:
thanks,
Old Nov 25, 2022 | 11:44 AM
BULL's Avatar
BULL
Moderador
My best recommendation is:
Silicone spray
Heavy duty long needle nose pliers: Straight, 45 degree and 90 degree
Razor/knife
Cut the old one out and leave the the hose clamps in dangling in the metal lines.
Remove the old pieces of hose.
Spray some silicone lubricant onto the new hose and metal pipes.
Bend the new hose into a U and slide it into place then return the hose to relax position and insert it into both pipes, lastly fit over the hose clamps (new or used)
Good luck.
Old Nov 25, 2022 | 01:59 PM
si_driver's Avatar
si_driver
thanks, makes sense
Only thing is there is very little room.
Silicone spray
Razor/knife
Good luck.
jkorchemniy
Sep 7, 2019 02:41 PM
jkorchemniy
Apr 11, 2018 11:27 PM
saywat?
Apr 18, 2017 03:01 PM
andi
Apr 16, 2017 08:55 PM
tite_tite
Sep 25, 2015 10:21 PM
