Oil in spark plugs
Old Sep 9, 2021 | 11:40 AM
Milo Ruiz's Avatar
Milo Ruiz
Oil in spark plugs
I had oil in spark plugs a couple months ago I changed my valve cover gaskets and now my car has been running bad so I looked inside some of the spark plugs and now oil is in there once again but in 2 plugs now instead of the 1 before did I mess something up? Is there another things that can cause oil in spark plugs
Old Sep 9, 2021 | 11:46 AM
RMB5190's Avatar
RMB5190
Definitely a gasket failure. Did you use OEM gaskets (new case gasket and plug gaskets), liquid gasket in appropriate places and tighten using factory torque specs?
Old Sep 9, 2021 | 03:42 PM
Milo Ruiz's Avatar
Milo Ruiz
I thought I did but the bolts looked loose so I tried tightening them and now One snapped off along with the spark plug tube bolt so both ends are stuck in there I tried drilling them out but I think I only made it worst this car gets on my nerves lol
Old Sep 10, 2021 | 11:14 PM
crookncastle's Avatar
crookncastle
this is funny as all hell. you are mad at the car for your own screw-up? i think you more than answered your own question when you asked if you messed something up after revealing that you broke the bolts/screws. if you don't know what you are doing pay someone to do it.
Old Sep 11, 2021 | 12:32 AM
Milo Ruiz's Avatar
Milo Ruiz
never said I was mad At the car or that it was even the cars fault we all learn some how and that’s how I learned this one. I said the car gets on my nerves in general be positive brother
Old Sep 11, 2021 | 10:21 PM
Noogie Lamont's Avatar
Noogie Lamont
Rule number one of changing spark plugs.
Always use a magnetic Spark plug Socket.
This is right up on the level of people using jack stands to change their oil when a ramp will be a better option.
Point is the OP had an issue and then broke off a spark plug. We all have done it. But to the OP. You have a bigger issue. You have oil on the plugs. Its time to bring it to a specialist. If the gaskets were changed they don't seem like they were done properly. Its not your plugs. You will just have the same issue with new plugs. And please don't try to drill your broken plug out. Then you will have metal all over the tube. Just go buy a magnetic spark plug socket for ten bucks and you will get the plug out without issues.
Old Sep 22, 2021 | 12:30 PM
crookncastle's last comment has been deleted.
Hard stop for attacking forum members.
Old Sep 23, 2021 | 12:43 AM
mummy2's Avatar
mummy2
You read wrong. He broke the bolt not the spark plug.
Stachuu
Feb 17, 2020 12:30 AM
skriLLah
General Tech Questions
Jun 10, 2018 04:58 PM
Flakman
May 27, 2018 09:16 PM
antirice
Nov 12, 2017 02:28 PM
Chappedj
Sep 28, 2015 03:20 PM
