High Mileage on G37
Old May 21, 2019 | 03:23 PM
  #91
si_driver's Avatar
si_driver
my 2012 g37 only has 89k now, by 2003 G35 is rocking at 280k without any issues.
Old May 21, 2019 | 08:57 PM
  #92
Eddie Ex's Avatar
Eddie Ex
Originally Posted by nonlinearedits
I'm at around 84k on a '10. All oil changes and brakes for the most part. I've owned it since 50k. I had one LED out in the ring of the tailight (can't replace the single LED) extended warranty covered replacement of the entire taillight. I replaced the belt myself after the dealer told me to because mine was rotting. I cut off the old belt to get it out and found out they lied to me and it was in perfect condition. One of the OEM cats rattled like crazy around 75k so I replaced them with Berk HFCs. Other than that I'm really just awaiting the galley gasket failure lol but I installed a pressure gauge so I can catch it early.
How do u like the berks hfc's so far.. are they louder than the OEM's. Did you get cat back with it? One of my cats just went and I'm about to get some but I don't want the race car sounding ones...lol
Old May 21, 2019 | 09:08 PM
  #93
Eddie Ex's Avatar
Eddie Ex
Originally Posted by jcho01
From the SEL Diag, one of two OEM Cats is going bad. I have 130k miles on them.
Same here... the passenger side one and both 02 sensors codes before the cat on intake manifold ate popping up. I have 133,000ok now... power is low and mpg too
Old May 31, 2019 | 11:16 PM
  #94
usedG37's Avatar
usedG37
119k miles sedan X. I bought it used and it looks like the wheel bearings were replaced. I’m not really sure about any other issues it had but I can’t see anything else visually.
I replaced the plugs, front/rear diff oil -and accessory belt. Thinking about replacing tranny fluid
Old Jun 2, 2019 | 10:22 AM
  #95
4DRZ's Avatar
4DRZ
It's never a bad idea to inspect/replace the transmission fluid. Most transmission issues we see at work are due to people never changing the fluid. Just saw a Murano with issues after 147,000 miles and zero transmission flushes!?! The fluid was like tar when it came out.
Old Jun 2, 2019 | 10:38 AM
  #96
nonlinearedits's Avatar
nonlinearedits
I wonder if the CVT in the murano ages fluid differently. Those CVTs are a nightmare.
The transmission is sealed on the G37 so you’ll need someone with a pump to get the fluid out. Make sure whoever’s doing it knows what they’re doing. Nissan calls it lifetime fluid but we all know how that really pans out. I wouldn’t say 119k is real high up there my wife had a VQ maxima years ago that she still sold for 3k with 200k on the clock. It’s high for a Chevy but it’s say that’s midlife right there. Should get a lot of life out of that car still.
Old Jun 3, 2019 | 10:34 AM
  #97
4DRZ's Avatar
4DRZ
The CVT's used to have a maintenance interval of 30k, then 60k, and now they just say to inspect the oil every 30k. The only time my shop sees issues with them is when people don't bring their cars here for regular maintenance. They go to some corner shop thinking they are saving money, but they have none of the tools, tech, or knowledge for modern cars- especially the electrical systems. The techs at the "non-stealership" don't carry CVT fluid so they try replacing it with cheap oil or just skip it entirely and then wonder why they have issues at 147k... I cannot remember the last time we had a car that is serviced here regularly that had an issue with it.
Old Jun 3, 2019 | 10:59 AM
  #98
nonlinearedits
That makes sense, I can't stand CVT so I never owned one to have to learn about the maintenance but I know a few people with Murano's that all roasted their trans, actually my buddy has had his sitting in the drive way for a year now because he doesn't want to deal with it. That being said I know all those people went to independent shops, so that would definitely explain that. Thank you for the insight.
Old Jun 3, 2019 | 02:25 PM
  #99
4DRZ's Avatar
4DRZ
I'm not a fan of CVT's either, but mainly just because I do not like A/T. I would much rather drive a M/T, but they are becoming very difficult to find.
Old Jun 3, 2019 | 03:08 PM
  #100
nonlinearedits
Amen, I needed a sedan bc I have two young kids and finding a M/T sedan was near impossible. I was excited to see the sedan auto at least had gears still lol
Old Jun 3, 2019 | 03:17 PM
  #101
4DRZ's Avatar
4DRZ
I have been searching for a Cadillac ATS-V sedan 6spd. with a few important features and I have yet to see one in the last 6+ months?!? If I wanted A/T I probably could have bought the car 10 times over. Stupid A/T cars.
Old Jun 3, 2019 | 08:19 PM
  #102
TinsleyC's Avatar
TinsleyC
I have an '09 with low miles, 79K - no major issues I can recall, but I've taken care of it. Did replace the trans fluid at 76K. There was some considerable warranty work done on 10/14/13, the dealer found and did all the work after I asked them to look over the car well and replace anything that needs it before warranty expires.
Right now the front right brake caliper is rattling, need to get that fixed.
Date Mileage Service
07/27/09 3,800 Oil change by dealer.
11/03/09 6,465 Oil change by dealer.
11/04/09 6,470 Bought as new car (dealer demo) from Sewell Infiniti on Lemmon Ave in Dallas, TX for $32,700.
12/19/09 7,580 Rotate & balance tires.
12/22/09 7,704 Applied ITB09-032B for harsh downshift from 4-3rd gear. Replaced broken grocery net hook.
03/02/10 9,716 Oil change, Pennzoil Ultra 5W-30.
07/24/10 13,773 Oil change, Pennzoil Ultra, Purolator filter.
07/24/10 13,773 Replaced cabin air filter. Repaired center cup holder lid closure.
08/10/10 14,100 Rotate & balance tires.
10/09/10 15,655 Installed Infiniti sport paddle shifters bought from Riverside Infiniti.
10/12/10 15,711 Front rotors turned and front disc pads replaced due to Service Bulletin ITB09-037a[1].
02/17/11 18,408 Changed oil, Pennzoil Ultra, Infiniti filter. Applied ITB09-032B again although the tech told me it was really ITB10-075.
05/28/11 21,001 Rotate & balance tires.
06/22/11 21,722 Replaced wiper blades with OEM blades.
08/23/11 22,810 Oil change, Pennzoil Ultra 5W-30, Purolator filter. Performed ITB10-075 Transmission Reprogramming.
09/03/11 23,025 Replaced engine air filters (2).
01/13/12 25,294 Vent control valve and car battery replaced per ITB10-010C. Replaced peeling instrument panel cover. Adjusted hood closure/play. A/C Mode button sticking, replaced Switch Assy.
02/25/12 26,094 Replaced cabin air filter.
03/27/12 26,782 Changed oil, Pennzoil Ultra, Purolator filter.
04/22/12 28,080 Rotate & balance tires.
06/23/12 29,831 Replaced tires, Yokohama YK-580's.
06/27/12 29,924 Performed ITB12-027A, replaced differential oil, 4-wheel rotation.
11/03/12 33,377 Changed oil, Pennzoil Platinum, Pennzoil filter.
01/28/13 35,054 Replaced rear brakes, turned rear rotors. Replaced valve cover gasket.
03/12/13 35,723 Rotate & balance tires.
07/13/13 37,906 Changed oil, Pennzoil Platinum, Pennzoil filter.
10/14/13 40,244 Warranty work: replaced steering rack, A/C compressor, fixed mud flap, replaced instrument panel plastic, fixed dash rattle, state inspection, four-wheel alignment.
11/04/13 40,600 Car factory warranty expires (4 years).
11/18/13 40,949 Replaced car battery, no charge.
01/13/14 42,093 Rotate & balance tires.
04/12/14 43,488 Changed oil, Pennzoil Ultra, Pennzoil filter.
10/18/14 46,693 Replaced engine air filters (2), Purolator
10/19/14 46,694 Replaced cabin air filter.
10/25/14 46,779 Changed oil, Pennzoil Platinum, Pennzoil filter.
10/30/14 47,280 Lubed front brake caliper pins to quiet rattle. Replaced window tint on front left/right windows to allow passing State Inspection.
04/16/15 50,500 Replaced wiper blade refills with OEM blades.
06/13/15 51,564 Changed oil, Pennzoil Platinum, Pennzoil filter.
06/20/15 51,821 Rotate & balance tires.
07/18/15 52,873 Turned front rotors
02/20/16 57,672 Changed oil, Pennzoil Platinum, Pennzoil filter.
04/25/16 58,792 Rotate & balance tires.
10/01/16 62,125 Changed oil, Pennzoil Platinum, Pennzoil filter, Inspection
11/09/16 62,654 Replaced air filters (2), WIX
11/09/16 62,654 Replaced cabin filter
01/30/17 64,014 Flushed brake fluid, replaced rear differential oil, flushed coolant - replaced with CPBLUE antifreeze. Reattached RR wind flap.
03/16/17 64,682 Replaced tires, Yokohama YK-740 GTX
07/23/17 67,449 Valvoline Synthetic oil change and filter
12/16/17 69,800 Replaced battery Econocraft 24F, installed new Centrix brake rotors and pads, 4-wheel alignment.
03/17/18 71,192 Valvoline Synthetic oil change and filter
04/13/18 71,577 Rotate & balance tires.
11/19/18 75,838 Replace/Flush transmission fluid
12/08/18 76,071 Valvoline Synthetic oil change and filter
12/09/18 76,080 Replaced battery, DuraLast Gold 24F, self install
04/01/19 78,499 Rotate & balance tires.
Old Jun 24, 2019 | 10:10 PM
  #103
KellingFrenzy's Avatar
KellingFrenzy
2009 G37x 136k
Had my G for just over 8 months now. All the mods i planned on doing pretty much took care of any preexisting issues.
First was FI HFCs because of a CEL code for cat inefficiency. Turns out the previous owner pulled the stock cats, bored out the webbing of precious metals, welded any openings, and then put them back on 😑 Custom test pipes I guess.......
Other than that everything feels great and I just replaced the sparks, cleaned the Throttle Bodies, and actively keep up on fluids.
Old Nov 7, 2019 | 05:56 PM
  #104
panini's Avatar
panini
Brought my 2012 G37 (132k miles) in for rear brakes and was given a laundry list of other stuff that's wrong. Been going to the same dealer since I got the car in 2013 and there has never been any mention of things that might be going wrong or 'keep en eye on this'.
I'm really not amused at this list:
Radiator hoses leaking($600)
Valve cover leak($1600)
Rear bypass hose leak($1000)
Steering rack ($2,400)
Rear subframe leak ($2400)
After reading through this thread I'm even more suspicious that the list is b.s.since no one seems to have had any of these issues let alone all of them at the same time. They sent pictures but will have to show them to me when I go pick up the car later today.
Old Nov 7, 2019 | 06:21 PM
  #105
JSolo's Avatar
JSolo
Just say no!!!!!
Did they show you what's leaking where, or just present a list? Based on those prices, you might as well get rid of the car
