High Mileage on G37
Old Feb 13, 2020 | 10:43 PM
  #136
ezbme's Avatar
ezbme
How about that recall with the fuel system? Perhaps you are having a problem with your fuel pump
Old Feb 13, 2020 | 11:06 PM
  #137
G37xMN's Avatar
G37xMN
How can I check if I qualify for a recall?
Old Feb 14, 2020 | 09:30 AM
  #138
4DRZ's Avatar
4DRZ
Have any Infiniti shop run your vin or even easier, just put it into the NHTSA site: https://vinrcl.safercar.gov/vin/
Old Feb 14, 2020 | 11:55 AM
  #139
G37xMN's Avatar
G37xMN
shows zero recalls for my vin.
Old Feb 16, 2020 | 08:01 AM
  #140
2012G37's Avatar
2012G37
Almost 164k, and this how I'm rolling;
That cut off revving issue return then all came to an end with no more power. Revving issue is due to a Gear 2 Incorrect ratio plus I need a new battery. 😥😥
Old Feb 16, 2020 | 11:09 AM
  #141
G37xMN's Avatar
G37xMN
What is your cut off revving issue? I had this problem with my car on a trip across the US where I would put the throttle down like 3/4 and the revs flew up but it wouldn’t accelerate. Only happened after like 15 hours of driving through windy roads and hills.
Old Feb 16, 2020 | 09:54 PM
  #142
2012G37's Avatar
2012G37
Well at around 3k RPM, it would go into a limp mode. This issue happen 3x within 4weeks, then I struck out. I couldn't find alot of info on this issue so I'm assuming its a rare issue to happen. A coworker who had a 1st Gen G35 had similar 2nd gear ratio error, a solenoid replacement fix that problem. I'm sure that tranny is totally different from the 7at.
Old Feb 27, 2020 | 07:20 AM
  #143
John L Williams's Avatar
John L Williams
Mr Williams
Originally Posted by AbeG37vq
Hello everyone. I was just wondering if there are any people out there who has a G37 with high miles, say over 100K miles. How is the G37 holding up? What are the issues we should be keeping an eye on as the mileage keep racking up? Thanks.
I gave a 2009 Infiniti g37x 248,000 miles no leaks runs strong even @120mph.......Don't recommended that.. lol.
Old Feb 28, 2020 | 05:20 PM
  #144
monty2003's Avatar
monty2003
142k miles here. All fixes DIY except welding. Followed the factory service recommendations and nothing more.
Major fixes
new Steering rack
drivers side cat
cross member rusted - had it welded up. Stripped bolt holes too with all of the rust.
Minor Fixes:
Rear brake calipers x4.
RF wheel bearing
Needs:
Passenger cat
Shocks/struts
lower ball joint right front.
occasional o2 sensor code
Still runs like a champ. WOT every day. My enemy is rust. This car will rust out before it is dead. Chicago winters and salt are rough on cars. My son turns 16 in 2.5 years. Would be a sweet car for a 16 year old to drive - even at with a ton of miles so hoping to keep it going.
Old Mar 31, 2020 | 09:08 PM
  #145
Criss323's Avatar
Criss323
09 G37s sedan high mileage
Hey everyone I am currently going to change my Rear differential oil On my g I currently have 129 thousand miles on it any recommendation on the oil I should use ?
Old Mar 31, 2020 | 09:50 PM
  #146
spock's Avatar
spock
Not really a great car for a new driver unless he/she is very responsible. It's power is typically beyond a new driver's experience.
IMO of course.
Old Apr 1, 2020 | 06:55 AM
  #147
IMO of course.
Which makes it the perfect car for the experienced, irresponsible driver.
Old Apr 1, 2020 | 07:51 AM
  #148
4DRZ's Avatar
4DRZ
Old May 18, 2020 | 07:02 PM
  #149
Lynn49's Avatar
Lynn49
2013 - 140k miles and zero issues. Oil change every 4k miles, changed plugs at 100k, powerstop brakes and rotors, K&N air/oil filters, its been a great car.
Oh, my cats are making noise but will be changing those soon.
Old May 18, 2020 | 07:16 PM
  #150
G37sPhoton's Avatar
G37sPhoton
^^wow you've been driving, im at 122k and plugs at 107k, new pads/rotors at 110k and so far, minor issues that at least can be fixed mainly diy so still a great car...but the paint has chips...like im going to vegas chips and a while ago i got a dr colorchip road rash kit and did some touching up..a lot of touching up and then some wet sand and polish and not bad results, but more are popping up so not sure on next move...
