Old Dec 1, 2023 | 12:35 PM
  #9631
rotarymike's Avatar
rotarymike
Moderator in Moderation
Wow. I think we've got 20 years left LOL but we pay a little more than due to shorten it. My wife ran the numbers on that and has it all set up.
Last year's BF I got a new laptop - got 70% off a new Lenovo X1 Carbon. So far it's boringly competent LOL. Next maybe is one of those 49" wraparound monitors. I doubt I'll need another one unless there's a quantum breakthrough (literally) and all the OSes change dramatically. Also managed to get lifetime MS Office 365 licenses for mine, my wife's and my daughter's computers.
I picked up a small compressor from harbor fright for our bikes 2 years ago, also kicks butt at low tires on the cars. https://www.harborfreight.com/12v-10...tor-63745.html
I'm looking forward to the week between Christmas and NY having off, so I can put the G on stands and do some stuff. I'll even have help in the form of my FIL.
Old Dec 1, 2023 | 02:11 PM
  #9632
socketz67's Avatar
socketz67
Community Builder
Re: the diff bushing... dropping the diff is relatively easy. Remove exhaust section that covers it, unplug sensors, unbolt everything and it comes down easily. Fluid won't come out unless you turn it upside down (through the vent tube) or you pull a stub axle.
The damn bushing... although I don't have a lift, I've got all the right tools for this and still ended up using the drill-the-rubber-cut-the-sleeve method, then lots of hammering with a cold chisel until the sleeve peeled away from the subframe and I could get it loose enough to move. It had rusted in there pretty badly. Went through with wire wheel on a drill then a sandpaper wheel to clean it up, and used plentiful silicone grease when putting the new (in my case, Whiteline) one in. My daughter came to check on me under the car and apparently learned some Air Force mechanical lingo in the process before I realized she was there.
IMHO, this was worse than the demon bolts on the header/cat flange. Those I went into the operation knowing I was breaking them off, and just had to get enough torque on them. However, end product = worth it.
@RobC7 @rotarymike
I finally got around to replacing my diff bushings (used Z1 polyurethane) here locally (decided not to drive to Pitstop in AZ). One of the Techs at the shop I use has a 240Z and had replaced his recently, so he understood the difficulty of task at hand. Took him 8.5 hours and a broken bushing professional removal tool, but I was only asked to pay for 7 hours. I talked to him when I picked the car up and he said that drilling out the inner core (see the pic below), then using a zawsaw to cut/bend the metal insert worked. He then had to cut a piece of pipe the same diameter to pound the piece out as it was rusted in place and wouldn’t budge. I am in awe of you guys that were able to do this work with the car sitting on jack stands. I’m not worthy!
I would highly recommend this upgrade as the car feels like a much better version of itself, firmly planted (the odd “wobble” in the rear is gone) and an instant transfer of torque. I realize now that the blown bushing also caused a weird vibration when backing up and taking off. It appears that I had just gotten used to the lackluster performance of the oem bushing and didn’t realize what I was missing as the rear of the car feels much more intuitive now.
Anyway, I appreciate all the guidance you guys provided. Definitely not a cheap mod, but my birthday is in a week and interviews are going well, so I treated myself to a set of diff bushings.
Old Dec 1, 2023 | 02:20 PM
  #9633
rotarymike's Avatar
rotarymike
Same here. Drill/sawzall around, push out rubber and center tube, and then chisel/beat/curse on the outer sleeve.
Old Dec 1, 2023 | 03:52 PM
  #9634
socketz67's Avatar
socketz67
Community Builder
Both pics of ours scream <insert curse words>
Nissan did not design that bushing to be removed. I’m still a little confused as to why they didn’t use a solid rubber bushing as this is what was used on the 240Z and what’s available through most aftermarket automotive suppliers. We likely could have gotten 5 more years out of solid rubber bushing.
I’m struggling to find a tradeoff with the polyurethane bushing as it’s night and day with no noticeable NVH increase.
Old Dec 1, 2023 | 03:55 PM
  #9635
Poly motor mounts are next.
Old Dec 1, 2023 | 04:12 PM
  #9636
rotarymike's Avatar
rotarymike
LOL @ the do-iiiiiit
Make sure you leave one mount with some flex. Trans mount seems to be the right choice for OEM - the poly ones create a lot of NVH I've heard.
IF NVH doesn't bother you, there's always Delrin...
Old Dec 1, 2023 | 04:25 PM
  #9637
ILM-NC G37S's Avatar
ILM-NC G37S
...active search for replacement (vehicle) will be ASAP after the new year.
I've begun the search to replace my 25-year-old beater pickup. The market still stinks.
I'd rather have a lobotomy, root canal, and kidney stones... at the same time...
Good luck on your search!
Old Dec 1, 2023 | 04:45 PM
  #9638
rotarymike's Avatar
rotarymike
Ford Maverick, if you can find one.
I, on the other hand, am on the hunt for a sub-$5k work van. Ford or Chevy doesn't matter, just want a RWD one that can tow a car trailer and maybe a box trailer if I ever get really wealthy.
Old Dec 1, 2023 | 07:49 PM
  #9639
ILM-NC G37S
Nope. Likely getting a Toyota Tacoma... hopefully by April 2024. Given their reliability and my usage, the truck will likely outlast me. If I can find a decent one. The used market is just as bad as the new market these days...
Then there's a 'Vert...
Old Dec 1, 2023 | 09:00 PM
  #9640
SupraOfDoom's Avatar
SupraOfDoom
Z1 tool, 6 hours of tedious extreme cranking and kicking with two people, bruises, and a bent ARP is all it takes to get that diff bushing out. No problem.
Old Dec 1, 2023 | 11:03 PM
  #9641
socketz67's Avatar
socketz67
Community Builder
agree. Love the one you’re with seems to prevail in the current market. When I picked my car up today, my mechanic told me that the car was in great shape and would likely outlive me. Not sure how that makes me feel ?
Old Dec 3, 2023 | 02:35 PM
  #9642
SupraOfDoom
Only 37 degrees out, but that won't stop me! Installed the Z1 diff brace today. I originally had a Bell Racing Diff brace but it wouldn't clear my exhaust so I had to sell it. This one not only was designed specifically with the Z1 diff cover in mind, but it also can be used as a jack point! If you have the Z1 expanded cover you lost that function without this. Pretty rad! Took about 1 hour to install but I had to have my son help me for the top bolt. Kinda need 3 hands for that one.
Old Dec 5, 2023 | 05:47 PM
  #9643
Josh South's Avatar
Josh South
I plan to replace the gallery gaskets on my car this winter. I ordered all the hardware and gaskets from z1. I also added a new OEM water pump and thermostat because why not? I will also refinish the timing cover with some gunmetal gray cerakote to match the rest of the car and top off the engine bay. After that, I will be getting a rear 370z Nismo sway bar. This will be my first time in a car engine other than replacing a valve cover on a friend's N54 engine. I'm looking forward to getting this done.
Old Dec 5, 2023 | 06:06 PM
  #9644
dkmura's Avatar
dkmura
20 Year Member
Finished an oil/filter change to my oil of choice: Mobil 1 0-40 FS and Nissan filter. I've had good results using this product and wondering what others think of M1 0-40 FS?
Old Dec 5, 2023 | 09:36 PM
  #9645
Josh South's Avatar
Josh South
Nice! I used to use 5-30 mobile 1. I did some research and talked with my tuner and he recommended 5w-40 shell rotella t6 diesel oil. So that's what I'm using now with a K@N filter. Seems to be working well after 3 oil changes. That M1 0-40 seems like it would be a good choice.
