Old Nov 5, 2022 | 11:50 AM
  #9211
STownSaint's Avatar
STownSaint
Originally Posted by SomeName
Yeah, for me the beauty of the G is I don't have to anything to it. Perfectly satisfied with stock performance. That why I never have anything to post here. But I still keep up on new posts.
Tahoe is another story. It's a 96 with ~45k miles. Been chasing coolant leaks ever since I got it. Water pump, radiator, this dumb little heater core diverter valve. This past summer I did the intake manifold gasket. It has zero rust so it's relatively easy to work on.
Same here, all of my mods in my 10 yrs of ownership have been cosmetic. Keep kicking the cold air intake further out. I don’t know, the potential issues like MAF sensors and water intake are enough to hold me back (even tho risk seems very low). Exhaust, I like the car sounding low key (love how some of the systems sound of other people’s Gs though). Suspension, I’d love the car to sit a little more aggressive, but it’s fine at stock ride height (and city roads aren’t the best, I’d have to drive more carefully). And I’ve heard suspension parts come with unexpected creaks and rattles. Not wanting to sacrifice things there.
So basically, I’m super lame but admire what other folks are doing to enhance their cars
Old Nov 5, 2022 | 01:59 PM
  #9212
Selym's Avatar
Selym
I drove it to an apple farm and bought some cider.
Then I drove way out of my may to a far away Walmart, where I bought three, 5.1 quart containers of motor oil for upcoming oil changes. After that, I took my time coming home and drove back roads. There's something about how the car runs really well in the Fall. I don't know what that's all about, but this time of year every year I get to thinking how much the car likes the weather. It sounds better, it responds better, it just feels better... which is all in my head, I'm sure. Not that there's anything wrong with that.
Nice Autumn day today.
That crisp, cool autumn air is denser, which results in a greater mass of air being metered, thus more fuel, and better performance! Drag racing enthusiasts know this well, as do pilots (high & hot is no good).
Old Nov 6, 2022 | 07:57 PM
  #9213
I'm sure someone here has an opinion on why Fall weather is so agreeable to the car. Maybe I'll ask my buddy today, he's an engineer and usually has an answer for everything.
He said it's in my head.
Old Nov 7, 2022 | 08:06 AM
  #9214
BULL's Avatar
BULL
Moderador
Anyone here dealing with dealing with noisy telescoping motors?
I have a spare column with motors that I want to replace with.
The ones in the column needed the brushes changed and was able to bring them back however everyone in a while the in and out motor just doesn't react, a pull of the wheel while hitting the switch get's it moving however it's constantly moving daily.
This is a feature I refuse to live with and will try to keep it going.
My concern: In a 4WAS G37 the front actuator is built in the steering column. They are physically different and probably the queen as far as value goes. Many other things are exchangeable.
In the event this column starts to give me mechanical problems, a replacement is just not going to happen
Don't buy a rebuilt All Wheel Steering car folks
Old Nov 7, 2022 | 06:59 PM
  #9215
FrogmanKouki's Avatar
FrogmanKouki
Need your opinions on a potential wheel set up for the winter!
With cooler temperatures approaching (forecasted to be below 30° this weekend) It's time to find a non summer tire solution. Which means storing the Rays and getting another set of wheels.....
There are a few different sites that have confirmed wheel fitment on the Akebonos (https://conceptzperformance.com/wiki...heel_Clearance) . However the G35 Coupe Base wheels I have on my S14 are on the list but claims they will not clear. These are 18"x8" with a +30 offset and the fronts just barely clear the barrel of the wheel WITH 10mm spacers. Keep in mind the current tire OD was sized for an S14, I have 245/45 tires on order this week which should bring the OD to the G37 size. I guess these can be said to clear but only JUST. I'm not sure how much the wheel will deflect if at all.. And it's doubtful I will be driving the car in snowy conditions, so not too worried about snow and slush build up. Do you all think this is TOO close?
EDIT: Added daytime photos.
Grey on Grey...again, larger tires coming this week.
The closest of clearances.
Video gives the best example.
Old Nov 8, 2022 | 09:28 PM
  #9216
AnotherVQ's Avatar
AnotherVQ
Yesterday I installed a new dashcam and radar module:
Today I did the Q60 boot and shifter swap:
Old Nov 8, 2022 | 09:39 PM
  #9217
abrecos's Avatar
abrecos
Here is mine version.
Old Nov 13, 2022 | 07:24 PM
  #9218
thescreensavers's Avatar
thescreensavers
I've been having this really bad exhaust rattle 3-4k RPM, found my center support bearing heat shield was rattling really bad. I had an idea and had some wheel weights so I stuck some on each end of the heat shield and wow what a difference! No idea if the heat will make them fall off but we shall see.
If you guys have an exhaust rattle check out that center support bearing heat shield.
Old Nov 15, 2022 | 11:54 AM
  #9219
Today... swapping out the Vossens and Continentals for duckfeet & snows. That doesn't mean the car will get driven much in the winter, it just means when that happens, it will be with snow tires and wheels I don't care as much about. Summer-only tires are no bueno in the winter, even if the roads are dry.
Front snows have 7 to 8/32" of tread. Rears are a solid 6/32". Safe for winter, ice and light snow, but not so much for heavy snow... which is OK if, like I said, I don't really drive it much.
Always a fun project, LOL. That's because I use 15mm wheel spacer adapters in the winter, that I don't use in the summer. All told between the spacers, and two sets of wheels, I actually have 3 sets of entirely different lug nuts involved. Oh, I have to lug (no pun) wheels up from the basement, then back down again.
I feel like I'm getting too old for this crap.
Old Nov 15, 2022 | 12:45 PM
  #9220
What's with that groove a 1/2" from the hub? I didn't notice that until actually looking at this picture.
[edit]
So I go back out to the car to inspect this groove. And while it certainly got picked up in this pic because of the lighting, in real life it's barely anything at all. You can feel it with your fingernail, like half a mm, if that. Weird.
Old Nov 15, 2022 | 02:04 PM
  #9221
thescreensavers
Probably a rock got caught and dragged looks pretty minor though, I wouldn't worry about it too much.
Old Nov 15, 2022 | 02:32 PM
  #9222
ILM-NC G37S's Avatar
ILM-NC G37S
Are you sure it is not the difference between brake pad to rotor surface area? Typically, pads do not cover the entire rotor "working" surface.
Old Nov 15, 2022 | 03:05 PM
  #9223
iCrap's Avatar
iCrap
I think if that were the case, the area inside the groove would be rusty or at least dirty. I see wear on the inner surface - so probably dragged a rock.
Old Nov 15, 2022 | 03:16 PM
  #9224
Yeah, I'm not going to lose sleep over this. Sure did concern me when I looked at that photo, though!
Old Nov 15, 2022 | 06:34 PM
  #9225
abrecos's Avatar
abrecos
I always use summer and winter tires sets on my car .it's like a Japanese proverb said that better to be a warrior in the garden than a gardener at war. You never going to predict the weather conditions especially at winter time. I bought Nokian Hakkapeliitta 9 studded winter tires and going to put them on these Saturday. All season tires not even comparable to good quality winter tires.
