Old Dec 5, 2020 | 09:45 PM
  #8281
Those seats are beautiful. Love the plaid. Going to look amazing with the carpet back in.
Good photos.
Old Dec 7, 2020 | 08:03 AM
  #8282
BoomerSpeed01's Avatar
BoomerSpeed01
Originally Posted by tsuintx
Thought about cleaning the engine bay of my latest acquisition I bought yesterday (2011 G37 Sedan). PO kept the car in great shape and maintained it well, but the engine bay was filthy.
Pulled out a rag and Purple Power and got to it, but didn’t get too far. Was wiping down the coolant expansion tank and without using too much force my finger broke through the plastc. LOL! That stuff was very brittle all over, actually. Was able,to pick up a replacement from local dealer (Grubbs in Grapevine, TX) for 85 bucks, so not a biggie.
Easy swap and the car is good to go again.
Wonder what happened to that reservoir that caused it to become so brittle... My coupe had over 250k miles on it and it didn't look like that or become that brittle. Very interesting. New one is beautiful!
Old Dec 7, 2020 | 09:24 AM
  #8283
rotarymike's Avatar
rotarymike
Moderator in Moderation
Did the car sit with the hood open for a long while? that's some serious UV damage...
Old Dec 8, 2020 | 08:49 AM
  #8284
BULL's Avatar
BULL
Moderador
Originally Posted by PNW_IPL
Boring yall need to post more pics!
You sure did change the look of this car. The black and red just didn't do any justice to how it looks now. Yes it might be boring when comparing to other members however unique when rolling around.
Great call on the carpet removal, it was one of those "Hmm, not too sure about this" however the red is what brings it out. The type of look you could only pull with solid colors.
Old Dec 8, 2020 | 11:57 AM
  #8285
RobC7's Avatar
RobC7
Originally Posted by backman_66
I just purchased a used set of nismo springs so I can report my results after I get them put on.
I've been doing some more research and I am seeing the 370z rear springs are much shorter and will drop the G too low. I'm seeing people using 370z front springs and modifying the rear spring isolator by cutting away 3/8th-1/2".
I also saw running these in the rear on stock springs should bring you down 1/2":
Amazon Amazon
Old Dec 8, 2020 | 12:34 PM
  #8286
backman_66's Avatar
backman_66
https://www.amazon.com/dp/B004ALJDPI...v_ov_lig_dp_it
Well that sucks, guess I got fooled into buying these because the guy said they will work on G's. Real nice!
Old Dec 8, 2020 | 05:13 PM
  #8287
backman_66's Avatar
backman_66
After thorough research, I did find one post that seems to solve this question about the nismo rear springs. It give about a 1.25" drop, which is more than I'm comfortable with. Hmm, what to do now......?
https://www.myg37.com/forums/souther...ml#post3281055
https://www.myg37.com/forums/private...o-springs.html
Old Dec 8, 2020 | 05:18 PM
  #8288
You could drop it with Swifts then raise it back up again with coil spring spacers.
Old Dec 8, 2020 | 05:22 PM
  #8289
backman_66's Avatar
backman_66
I was looking at this solution for $17..
https://www.myg37.com/forums/brakes-...ml#post4003553
I was hoping to keep this inexpensive, that's why I went with used nismo springs. If I get the swifts, then that's more money plus I'll have to buy LCAs too right?
Old Dec 8, 2020 | 06:25 PM
  #8290
rotarymike's Avatar
rotarymike
The earlier Nismo springs are stiffer - from my research should be about .5 - .75 drop only.
I bought a set too, so we'll see. Might have to do different front and rear springs.
Old Dec 8, 2020 | 06:40 PM
  #8291
backman_66's Avatar
backman_66
The example I quoted is from 2011 so he was using the earlier nismo red springs.
Old Dec 8, 2020 | 09:10 PM
  #8292
tsuintx's Avatar
tsuintx
Wondered that myself, too. And the thing is that it was just that corner. Everywhere else it was just discolored but not brittle. Go figure.
LOL! Maybe so since the hood shocks were tired, too. Guess these things either eat them a lot or then I’ve just bought the two out in the market that needed them since I had to replace them also on the 07. Just replaced them yesterday.
Old Dec 8, 2020 | 10:00 PM
  #8293
RobC7's Avatar
RobC7
From my research the Nismo fronts will be perfect but the rear will be too low. Options are:
- Run stock springs in the back and shave the rear isolators by 1/2" or buy ES isolator that is shorter than the stock isolator by 1/2"
- $17 solution from above to kick the height back up 1/2"
Old Dec 9, 2020 | 12:15 AM
  #8294
backman_66's Avatar
backman_66
I found something really cool that would have a lot of applications, not just for nismo springs. Its a company that sells different urethane spring rubbers in varying strengths so you can fine tune your spring rate and ride height. They're pricey though.
Here's a link to the product and also an article about them.
Longacre Coil-Over Spring Rubber 61005
Technical Articles
Old Dec 9, 2020 | 04:54 PM
  #8295
tsuintx's Avatar
tsuintx
Car came with only one remote, so I bought a new remote and key for 30 bucks off Ebay over the weekend. Received it today and had it programmed/cut by a locksmith for 58 bucks. Not sure how much a dealer would charge, but I'd imagine it wouldn't be anywhere close to that. For giggles, I might even do a third one, just in case...
