Old Sep 11, 2019 | 11:33 AM
  #7171
BULL's Avatar
BULL
Moderador
Originally Posted by OldG2NewG
So guy never came out, but I decided to go to the store and grab a nut a bolt and amazingly the bolt actually tightened and caught the threads so that's a good sign for one bolt hole lol. Bolt is to long but I can easily take it back and get a shorter one. Now to figure out the top left hole 🤔
Your only savior is to get a long bit and use the Tstat and drill the block straight, tap it then a stud, I would do the same with the bottom one once you figure the left.
Old Sep 11, 2019 | 12:07 PM
  #7172
OldG2NewG's Avatar
OldG2NewG
Yup only thing I'm coming up with even though I'm terrified to go to deep into the block and do some damage that can't be fixed
Old Sep 11, 2019 | 02:34 PM
  #7173
PNW_IPL's Avatar
PNW_IPL
Installed my catback finally. Nice tone. Fitment was spot on. Baby approved.
OBX or ARK grip replica. Its 2.5 in and 2.36 in some areas. Mild exhaust even with z1 hfc. Will be installing stillen gen 3 tonight. Yes I previously had z1motorsports race intakes but needed something with a splash shield due to Seattle rain so im.going stillen g3.
Old Sep 11, 2019 | 08:12 PM
  #7174
PNW_IPL's Avatar
PNW_IPL
G3 installed.
Old Sep 11, 2019 | 08:29 PM
  #7175
You did that without dropping the bumper? From what I understand, that's difficult to do with the Stillen.
What are you going to do about the missing Fuji? I think Top Secret makes a raised blank plate for that area.
Old Sep 11, 2019 | 09:46 PM
  #7176
ngolbuff's Avatar
ngolbuff
Maybe waiting for a Ferrari logo to fit on the engine cover????
Old Sep 12, 2019 | 09:40 PM
  #7177
Lunchtime's Avatar
Lunchtime
voltmeter installed
voltmeter installed -> i had to sacrifice the illuminated cigarette bezel/trim
Old Sep 12, 2019 | 10:09 PM
  #7178
hexotic's Avatar
hexotic
DIY Cheapskate/Mod
I've seen volt meters with a USB port. Maybe that's a good option.
Old Sep 13, 2019 | 10:23 AM
  #7179
Lunchtime's Avatar
Lunchtime
I saw those volt meters with USB port(s) too. But after some long thinking, I know I wouldn't like having USB cables sticking out from that area of the dash. So I went with a regular meter.
Also, the Volt meters that have USB port(s) were longer in length, in comparison with the regular volt meter. I was worried that I might run into interference issues (if I'd went with the USB version).
Old Sep 13, 2019 | 10:38 AM
  #7180
hexotic's Avatar
hexotic
DIY Cheapskate/Mod
Ah, cool. Never looked into them, good to know the size is different.
Old Sep 13, 2019 | 11:57 PM
  #7181
buckeye15q40's Avatar
buckeye15q40
2015 q40 awd installed full exhaust and intakes
Old Sep 14, 2019 | 04:36 PM
  #7182
STownSaint's Avatar
STownSaint
Cloudy day in DC, so finally gave the G a much-needed wash. Car hasn't aged too bad, after 6.5 years of ownership (with only one in a garage). But I'll be booking a professional detail for early Spring to address some of the more noticeable paint imperfections.
Old Sep 14, 2019 | 04:58 PM
  #7183
I've been to DC a few times, enough to know it's difficult to keep a car looking good there year over year. Yours always looks good, IMO.
Old Sep 16, 2019 | 12:40 PM
  #7184
rotarymike's Avatar
rotarymike
Moderator in Moderation
What's behind it in the block? If it is just a water passage, then make sure you use RTV on the bolt stem and under the head. The rotaries I used to work on had two holes for the water pump housing that go into the block that were open to the water jacket behind them, and no worries once everything was properly gasketed and torqued.
Old Sep 18, 2019 | 03:28 PM
  #7185
2GoRNot2G's Avatar
2GoRNot2G
If your G is RWD then you can always install a USB port in place of the dummy switch plate between the seat heater controls... That's where I installed mine. I also installed a traction control defeat switch inside the center console while I was at it.
