Old Jun 15, 2019 | 06:33 PM
  #6916
iCrap's Avatar
iCrap
Installed my spc camber arms (pain in the *** with the bolts seized inside the bushings, toe bolts, and bellworks diff brace as well as changed the oil. Can't wait till I get my lift in then all this stuff will be way easier. Can't really drive around since the alignment is all screwy now but i'm hoping the diff brace will make a noticeable difference.
Old Jun 16, 2019 | 08:23 AM
  #6917
RMB5190's Avatar
RMB5190
Thumbs up
Underestimated how exciting it is to hit this little red button. For anyone on the fence about it...just get one already!
BIG thanks to RMB5190 for help with the install (not to mention turn signals), pretty awesome how supportive this community can be!
Had fun! Always an enjoyable experience chatting with another enthusiast.
Very clean car too BTW. Simple yet sharp. Forgot what it's like driving a civilized G37 lol.
Old Jun 17, 2019 | 03:52 PM
  #6918
OldG2NewG's Avatar
OldG2NewG
Finally decided to paint my akebonos that's been sitting in the box for quite some time.
Now to let them cure for.a few days and install them
Old Jun 17, 2019 | 06:44 PM
  #6919
2GoRNot2G's Avatar
2GoRNot2G
^ Looks good. That color is definitely going to stand out.
Just a suggestion, but I would highly recommend adding a clear top coat with a quality high temperature clear coat. It will really make cleaning the calipers easier in the future and also help prevent the color from fading.
Old Jun 17, 2019 | 06:47 PM
  #6920
2GoRNot2G's Avatar
2GoRNot2G
Originally Posted by hexotic
Yup, the hoses I have now go from an10 to an6 via reducers. It's sloppy because the right hardware is so hard to find.
I've been considering this same project so I'm looking forward to seeing everything installed.
Old Jun 17, 2019 | 06:54 PM
  #6921
Why have you been considering this? Just asking.
Old Jun 17, 2019 | 06:55 PM
  #6922
OldG2NewG's Avatar
OldG2NewG
Thanks I'll try to grab some tommorow
Old Jun 19, 2019 | 09:44 AM
  #6923
STownSaint's Avatar
STownSaint
Had VLED "triton v3" switchback turn signals on my car for about two years...until the amber LEDs on the passenger side burned out. They failed just beyond the warranty period, but VLED was nice enough to issue me a $50 credit, so I got these in 5.5K. These bulbs are nice and bright, and they're a few shades "cooler" than the OEM low-beams. A perfect match wasn't necessary for me, but the 6K option for these bulbs would probably look too bluish.
Here's how they look (again, install courtesy of RMB5190). Think switchbacks are one of the best ways to make our front ends look more modern (and dare I say upscale), without having to pursue redesigned headlamps.
Old Jun 19, 2019 | 02:44 PM
  #6924
Atowsley's Avatar
Atowsley
What kind of lift are you getting? I'm seriously considering one myself in the next year or so. I have the SPC camber arms on my car too and rear diff brace. The SPC camber arms were easy for me luckily. But, the alignment guys at Firestone were little wussies tho. Made me loosen the camber nut on top before they would work on the car (smh). I torqued it to 60ft/lbs vs. the 120ft/lbs and then drove it over to them. I guess since it was an aftermarket part they were afraid of busting it and then eating the cost of the part and repair. But still, C'Mon guys. They torqued it to 120ft/lbs when finished with the alignment. FYI, lifetime alignments at Firestone for $140. Pay once and can get your car aligned at no cost going forward. Worth it if you play with your suspension a lot.
Old Jun 19, 2019 | 02:51 PM
  #6925
Atowsley's Avatar
Atowsley
Nice Picture. Almost looks like you are in Europe.
Old Jun 19, 2019 | 07:52 PM
  #6926
iCrap's Avatar
iCrap
4 post with a jacking tray so I can still get the wheels off. the main purpose will be for parking / stacking cars so I don't want to do a 2 post.
The alignment guy claimed he couldn't get the camber and toe in spec even with the arms though. He got the toe in but he said if he adjusted the camber it also affected the toe, which makes no sense to me at all. So now i've got -2.4 on one side and -1.6 on the other.... Im considering just finding a shop which works on modded cars rather than firestone/ merchants, etc..
Old Jun 19, 2019 | 09:15 PM
  #6927
Atowsley's Avatar
Atowsley
That sounds odd. The Firestone guys got both fronts for me in spec with the SPC. Frustrating. Firestone guys did look at me weird when I said its an aftermarket camber kit.
Old Jun 20, 2019 | 08:12 AM
  #6928
RMB5190's Avatar
RMB5190
Benpak makes a good product if you're looking at two or four post lifts.
https://www.bendpak.com/car-lifts/four-post-lifts/
My dad has the 2-post and it's solid. Prices aren't insane either.
Old Jun 20, 2019 | 10:04 AM
  #6929
Baadnewsburr's Avatar
Baadnewsburr
I have been told this before by a few alignment shops too, both good shops and bad ones... used to think it was BS until it was told to me by a shop I had gone to a few times and which was a shop that is very reputable (but still sometimes lazy) and specializes in alignments on lowered cars and in particular does them on a ton of G/Z cars with the camber kits...whether or not the tech correctly identified it on your car there my be something on your suspension that is seized or binding that is causing the toe and camber to be moved together and which just requires a more experienced tech or one willing ot deal with the seized components (I find most do not b/c they charge flat rates for alignments and it takes time and the risk of breaking something can be high)
Old Jun 20, 2019 | 10:08 AM
  #6930
I've had my car aligned numerous times at my local Infiniti dealership, each time by the same guy, and often with me right there indicating my preference on camber. The SPC kit was installed by my mechanic, but the Infiniti Tech did the alignment, and he loved how much configuration flexibility was available.
Based on my limited experience, I'd say it all depends on the technician.
