Old Oct 9, 2016 | 06:57 PM
  #1741
Bear Slate's Avatar
Bear Slate
Finally got around to blacking out the window trim with some vinyl
Old Oct 9, 2016 | 08:02 PM
  #1742
Nice job Bear! G is looking good
Old Oct 10, 2016 | 02:25 AM
  #1743
Furlow's Avatar
Furlow
Bear that looks dope! The paint, wheels, and vinyl wrap work perfectly together. Totally changes the car.
Old Oct 10, 2016 | 12:51 PM
  #1744
andy92129's Avatar
andy92129
1960s Classic Plate from California DMV on My G37
The painful part was waiting 6 months for the residents at the Gray Bar Hotel in Folsom, CA to make it for me.
The Black plate with Yellow letters has a personalized message reads N2AGCAR because I'm "In to a G Car...."
Appearance looks nice with the Graphite Shadow paint.
Old Oct 10, 2016 | 01:02 PM
  #1745
ShuuraRG's Avatar
ShuuraRG
Originally Posted by 007pipeline
I was originally going to paint the calipers red.. but I am torn now..
Not sure if the red pop of the calipers would be good it bad.. the silver is just a really clean look right now
For what it's worth, I think the red would go much better with your setup!
Old Oct 10, 2016 | 06:51 PM
  #1746
Bear Slate's Avatar
Bear Slate
Thanks blnewt and furlow, i appreciate the feedback. Next mod is gonna be a cold air intake. Im leaning towards the stillen gen 3, is that the best in you guys opinion?
Old Oct 10, 2016 | 07:14 PM
  #1747
Furlow's Avatar
Furlow
I would say so. I went with the gen 2, because I didn't want to worry about rain and water getting in the filters. It's probably not a big deal, but I just didn't want to even think about it. As far as performance, yes the gen 3 is the best.
Old Oct 11, 2016 | 01:51 PM
  #1748
Daddy Fat Sacs's Avatar
Daddy Fat Sacs
tomato tomato...Ive had both stillen gen 3 and Takeda cai and both seem the exact same to me. Only diff is stillen require cutting, takeda..no cutting. flip a coin, can t go wrong either way
Old Oct 11, 2016 | 07:53 PM
  #1749
ShotgunDre's Avatar
ShotgunDre
Had the day off so I decided to knock a few things off the checklist.
Installed a grounding kit using the 8g subwoofer wire from my old audio system setup. Also painted my headlight shrouds gloss black then restored the lenses.
After paint & before restoration
After
Old Oct 11, 2016 | 08:07 PM
  #1750
Swen94's Avatar
Swen94
After
Great job. What brand of clear coat did you use for the headlights? I need to restore one of my headlights too
Old Oct 11, 2016 | 11:43 PM
  #1751
ShotgunDre's Avatar
ShotgunDre
Appreciate it Swen! I used Turtle Wax Headlight Lens Restorer. Had some pretty decent reviews online and was only $9 at Oreilly's.
Old Oct 12, 2016 | 01:26 PM
  #1752
staskz's Avatar
staskz
Dynamat + Insulation for the whole back area, rear shelf and the bottom. Pic shows progress no the complete job. Less rattling, less noise from outside and my sound system sounds way better now. Also did my trunk. Didnt take me a day to do but still.
Old Oct 12, 2016 | 04:38 PM
  #1753
Swen94's Avatar
Swen94
That's not a permanent restoration right? I have used some other headlight restoration before on another car but that only last so long and then you have to polish it again to keep it clear
Old Oct 12, 2016 | 04:45 PM
  #1754
MaQG37's Avatar
MaQG37
You're better off doing it with this method other than the off the shelf kits.
Sanded it down with 400 grit sandpaper, then 800, then 1200. I probably could have stopped at 800. Each time I sanded in a different direction so I could see when I had completely removed the previous grits scratches. Once it was leveled with the sandpaper I used Dupicolor automotive acrylic enamel clear coat. I tried Rustoleum painter's touch 2X but it left bubbles so I had to strip it off and redo it. The clear coat fills in the scratches from the sandpaper and leaves a UV resistant layer to prevent yellowing. After it cured for 48 hours I wet sanded with 2000 grit sandpaper to remove the orange peel distortion and then removed the scratches with meguiars compound and a DA polisher. Those final steps were surprisingly fast. The result is a glass clear headlight lens that will not yellow.
Old Oct 12, 2016 | 04:53 PM
  #1755
Swen94's Avatar
Swen94
Thank you. This was exactly what I wanted to do excpect I wasn't sure which clear coat to use for the headlights
