SEDAN | Official Aggressive Offsets & FAT Tires
Old Aug 21, 2015 | 06:28 PM
  #61
Originally Posted by ToXIc
i would run 19" but i drag my E370 coming out of the drive way if i tuck tires..
so if i do 20" i could somewhat tuck more but keep the same ground clearance.. at least that what i believe.. lol
Actually running 17s,18,19s, and 20s will all be the same at the fender (and the ground) you just adjust your sidewall height to compensate for a bigger or smaller diameter wheel. You'd have no issues running 19s on your ride, and you could even run a series taller if you wanted as long as the front to rear diameter isn't excessive.
Old Aug 22, 2015 | 10:45 AM
  #62
ToXIc's Avatar
ToXIc
SEDAN | Official Aggressive Offsets & FAT Tires!
Gotcha..
Old Aug 23, 2015 | 12:08 PM
  #63
m3clubracer's Avatar
m3clubracer
quoted from original thread
Why can't manufacturers make cars look like this in the first place. I know, I'm in the industry and I can't understand the design approval philosophy! Options Japan, OPTIONS!
Old Aug 23, 2015 | 12:12 PM
  #64
m3clubracer
Is there a similar post for X's?
Old Aug 23, 2015 | 10:45 PM
  #65
No, I think there's some Xs in this thread though.
The squared setup thread has a few too~
https://www.myg37.com/forums/brakes-...post-here.html
Old Aug 24, 2015 | 04:43 AM
  #66
nishfish871's Avatar
nishfish871
those are some nice looking wheels blnewt, those may be some good fall back wheels...
but looking for more of the JDM style like the following but those are 19"
Work Kiwamis
WEDSSPORT SA55M
Work Emotion CR
glad it helps!
Here's my car with the SA55M. Setup is 19x8 +35 with 20mm spacer, 19x10 +40. I think you might be able to get away with a 19x10 +40 in the front.
Old Aug 24, 2015 | 10:07 AM
  #67
ToXIc's Avatar
ToXIc
looks great man got a side shot?
Old Sep 29, 2015 | 09:14 PM
  #68
ToXIc's Avatar
ToXIc
any sedans running 19x10.5 +32 not sure if that will to too aggressive for the sedan rear.
any pics would be awesome!
Old Sep 29, 2015 | 10:47 PM
  #69
rks's Avatar
rks
I run 19X10 +35 in the rear with a 275 tire dropped on KWs. There isn't any constant rubbing but I'm tucked with maybe an inch at the most between the tire and fender. The tires do show some mild rubbing.
Old Sep 30, 2015 | 07:52 AM
  #70
But anyone else has to have at least 275s out back
Front
Vossen CVT 19x8.5" +32
Michelin PSS 245/40ZR19
3mm wheel spacers
Swift Springs & OEM sport shocks
26 3/4" floor to fender
-1.7* and -1.1* camber
Rear
Vossen CVT 19x10.0" +42
Michelin PSS 275/35ZR19
SPC Camber & Toe Kit
Tein Basis Coilovers
-2.2* and -2.3* camber
Old Sep 30, 2015 | 08:11 AM
  #71
Sweetness^^^^
What took you SO long???
Old Sep 30, 2015 | 08:18 AM
  #72
A lifetime of not caring about wheel fitment... until suddenly I did.
Go figure.
Old Sep 30, 2015 | 08:34 AM
  #73
m3clubracer
That is a perfect picture of perfect fitment to me.
Old Sep 30, 2015 | 09:26 AM
  #74
MaQG37's Avatar
MaQG37
Go figure.
I'll send you a care package consisting of "hellaflush", "illest" , "stancenation" decals to accommodate your new mentality. pm address.
Old Sep 30, 2015 | 09:50 AM
  #75
ToXIc's Avatar
ToXIc
not sure if the .5 difference in width and the difference in the offset will wash
here's what i'm looking at.
currently i'm 255/35/19 19x9 +30 and pretty flush but have some gap to the fender. looking at 275/35/19 19x10.5 +32 or even crazier +22
want flush but not really looking to poke out so the +22
