SEDAN | Official Aggressive Offsets & FAT Tires
Old Feb 27, 2019 | 11:45 AM
  #376
PNW_IPL's Avatar
PNW_IPL
Originally Posted by SupraOfDoom
I was originally going to do 275's in the front and 315's in the rear, but I think I'll go with 265's in the front since I've heard some regret going as big as 275. Plus that way my diameter ratio is perfect.
That setup looks pretty slick. You're getting spacers for BBK though still?
Thanks man.
the 275 isnt too bad. Its just so wide it soaks up the steering feel a bit more.
as for bbk ill need a 7-8mm spacer to clear these wheels with the oem akebono. I found a neat pair of hubcentric spacers with a 73mm outer for aftermarket wheels. With that ill also install extended studs when doing the bbk.
Old Feb 27, 2019 | 01:15 PM
  #377
slartibartfast's Avatar
slartibartfast
Part of the loss of steering feel is the change in scrub radius with the wider wheels and tires. As long as you like the higher grip in front more than the loss of steering feel, it's a good move.
Old Feb 27, 2019 | 01:16 PM
  #378
PNW_IPL's Avatar
PNW_IPL
agreed. To me the feeling is minimal but wanted to give an honest feel. The grip in corners is amazing nonetheless
Old Mar 7, 2019 | 08:27 PM
  #379
thekarter1's Avatar
thekarter1
Originally Posted by PNW_IPL
275 40 18 x9.5 +38
Any rubbing up front? Fender work? What’s ur floor to fender arch measurements? I have the same spec wheels and need new tires. Coming from 245. Was going to go 255 but if 275 fits then y not???
Old Mar 7, 2019 | 08:59 PM
  #380
PNW_IPL's Avatar
PNW_IPL
No mods.
0 rubs
nothing.
lowered on tein springs
not sure on height
Old Mar 7, 2019 | 10:44 PM
  #381
thekarter1's Avatar
thekarter1
No mods.
0 rubs
nothing.
not sure on height
Ok 275s it is. U liking the Achilles tires?
Old Mar 7, 2019 | 11:07 PM
  #382
PNW_IPL's Avatar
PNW_IPL
i do.
really quiet coming from gt radial brand.
grip is good.
drove in the snow just fine.
Old Mar 8, 2019 | 07:45 AM
  #383
SupraOfDoom's Avatar
SupraOfDoom
Fronts can actually handle more aggressive offsets than the rear lol. Usually doesn't work that way.
Old Mar 23, 2019 | 06:46 PM
  #384
PNW_IPL's Avatar
PNW_IPL
Lowered on coilovers now. At 26 in from fender to ground theres some rubbing upfront.
Old Mar 25, 2019 | 02:17 PM
  #385
2GoRNot2G's Avatar
2GoRNot2G
Fitment looks great. FYI... There's a small bump/hump on the upper front side of the front plastic fender liner that should be ground off. At the height your currently at you'll definitely rub there until you grind it off or until it wears down on its own. You may also need to trim the rear felt fender liners if you haven't done it already.
Old Mar 25, 2019 | 02:19 PM
  #386
PNW_IPL's Avatar
PNW_IPL
appreciate the info thanks!
Old Mar 30, 2019 | 12:36 PM
  #387
kb24mvp's Avatar
kb24mvp
First two pics are of my original set up with 275's in the rear and 245's with 15 mm spacers up front. Eventually went to 285's in the rear and 255's with 10 mm spacers up front with the same wheel set up.
This is my current set up with 305's in the rear (with the rear fenders widened 1-1/2" over stock) and 255's up front with 10 mm spacers. This is obviously much lower than I usually run the car but I had to show off my air bags for the show.
Love the quality and build! Tried looking but can't find a build thread if you even have one.
Old Apr 1, 2019 | 02:13 PM
  #388
2GoRNot2G's Avatar
2GoRNot2G
Thanks man. Much appreciated! Unfortunately I never started a build thread, so you won't find one. When I first bought the car this forum was just getting started so there wasn't really many people on it yet. G35driver was still the popular forum back then, so you'd have to go there to find the threads that show most of my early modifications.
Old Aug 22, 2019 | 11:56 PM
  #389
PNW_IPL's Avatar
PNW_IPL
Wish me luck lol
Old Aug 23, 2019 | 09:34 AM
  #390
ryanwhite74115's Avatar
ryanwhite74115
Sooooo...lift kit?
