Groaning Noise at Max Turn
Old May 5, 2015 | 07:01 PM
peterso2's Avatar
peterso2
Today I hit a big bump in a shopping center. I am not sure if its related but I just found that when I turn the wheel max left or right the power steering pump normally makes a higher pitched sound over relief. Now it is more of a grinding sound. Is it possible I lost power steering fluid? Is there a spot to check this? Is this a symptom or do others experience this on their G37 as well?
Thanks,
Jason
Old May 5, 2015 | 07:35 PM
qmantran's Avatar
qmantran
Open your power steering fluid reservoir and check the fluid level. Also check if there are lots of air bubbles in the PS reservoir when the car is running.
Old May 5, 2015 | 08:36 PM
peterso2's Avatar
peterso2
the reservoir looks good. I do have the CPO. I wonder if that would cover it? This grinding noise just appeared today which is odd.
Old May 5, 2015 | 09:08 PM
JinV36's Avatar
JinV36
I had a problem on my old car(non infiniti) but the PS resivoir was bubbling. It was due to the O-Ring being loose allowing Air to come in causing "air bubbles" and the annoying sound when turning.
But if your PS isn't bubbling , than idk. Did you hurt the axle?
Old May 6, 2015 | 11:13 AM
peterso2's Avatar
peterso2
This is when I clock wheel full turn in either direction. I get more of a grinding sound when pump is going over relief. I've never heard it in this manner before. So it occurs when you are not moving - or if you are trying to get into tight spaces maneuvering at max turn. Normally I've heard the pump groan but not grind like this. I will check if I see bubbles today in the reservoir. Infiniti says to bring it in and its covered if pump, if its a fluid flush then I pay for it. Maybe safe to bring it in, but nearest dealer is 1 hr away :-(
Jason
Old Jul 2, 2015 | 11:08 AM
ricky3454's Avatar
ricky3454
Having same issue!! What was the fix?? Let me know please thanks.
Old Jul 4, 2015 | 01:07 PM
peterso2's Avatar
peterso2
I haven't done anything yet with it...it was making a different sound than normal, but that was only when over relief. I am under Infiniti CPO plan so if it gets worse I will take it in later. If you take it to the dealer let me know what the find, I suspect it might be normal..but definitely sounds odd.
Old Jul 4, 2015 | 01:10 PM
AroundTheG37's Avatar
AroundTheG37
I have the same thing happening and plan on getting it checked soon (just need to find time to bring it in but I loathe going to the dealer). PS fluid level is fine.
Old Jul 9, 2015 | 11:25 PM
AroundTheG37
Checked under my hood while the car was running and noticed my power steering fluid was bubbling so looks like I have air in the line. Yay.
Old Jul 10, 2015 | 03:30 AM
JinV36's Avatar
JinV36
Find an OEM O-ring and thay should tighten the seal and stop the noise. It worked for my old car. Costed around 4$ and its for sure a DIY. Well for the Honda it was haha
timc00k
Feb 15, 2017 09:15 AM
Rybitron
Nov 18, 2015 03:11 PM
parkern
Oct 1, 2015 10:15 PM
BurtoN86
Sep 30, 2015 03:32 AM
MrRiv
Sep 29, 2015 04:59 PM
