Having trouble with HID fogs
Old Nov 21, 2014 | 06:26 PM
JonMS's Avatar
JonMS
I decided to tackle my HID fog install today and got everything out. connected the ballast and bulb to test and NOTHING. Flipped the connector around and NOTHING, spliced in a 9006 connector and NOTHING, flipped 9006 connector around and NOTHING. Ballasts/Bulbs work when connected to test bench. I've read that this should be plug and play but its looking like I might need a relay harness? Can someone please confirm? Stock H8 halogens work when plugged in to either connector.
Using Morimoto 5Five ballasts and have an array of test D2S Bulbs. Yes I'm using D2S bulbs in my fogs. Tried 35w ballast from my old Audi and nothing either!
Old Nov 21, 2014 | 08:44 PM
Twista's Avatar
Twista
Did you turn the fog light switch on??? Need to break out the multi meter and test to see if U got 12-14 volts coming from the plug.
Old Nov 22, 2014 | 10:27 AM
JonMS's Avatar
JonMS
I'm just going to order a relay harness. Stock bulbs work fine and I do not like how thin the wires are for the OEM fogs to put HIDs on them anyway. I'll update this if the relay harness fixes it.
Old Nov 22, 2014 | 08:12 PM
tbulsara's Avatar
tbulsara
you will need a relay harness, but that may not fix the problem...
this happened on my Lexus IS.. turns out i had a bad alternator and in turn a bad battery which was not supplying enough volts for the HIDs to come on.
Halogens will come on with less volts.. they just wont be on at full brightness....
Old Nov 23, 2014 | 10:54 AM
JonMS's Avatar
JonMS
HIDs ignite fine when connected straight to battery with headlights on. Battery was replaced 2 months ago as well
Old Nov 23, 2014 | 06:24 PM
JonMS's Avatar
JonMS
Figured it out. H8 connector wasn't making contact with ballast power. Made my own conversion harness and we're all good.
2K1 6T8
Oct 6, 2015 07:40 PM
mjnoles1
Oct 4, 2015 10:27 PM
MrRiv
Sep 29, 2015 04:59 PM
k19g37x
Sep 29, 2015 02:46 PM
halfbreedcuban
Sep 27, 2015 08:58 AM
