Delayed response when opening D/S door. Door jamb switch?
Old Nov 15, 2014 | 09:08 PM
CRiME's Avatar
CRiME
Hey guys,
I've noticed over the past month that sometimes when opening the driver's side door, there is a delay of a few seconds before the car 'reacts' to the opening of the door. In other words, the seat doesn't roll back, and the courtesy lights (and dome lights if I have them on) do not turn on. After about 6-7 seconds, the car reacts and everything works properly.
Similarly, if I have the car on and open the door, the door open indicator on the cluster does not show that the door is open - it takes a few seconds to register. All of the other doors are fine.
I see the door jamb switch, part number 25360-AD000, costs about $15. Does it sound like this might be the issue? Hopefully this is it, would be a cheap fix.
Diagram of the part:
Anyone ever experienced this before? How did you fix it?
Thanks
Old Nov 15, 2014 | 10:02 PM
G37Xtreme's Avatar
G37Xtreme
Can you swap the switches from driver side to passenger side? Are they identical?
If the problem goes away, it's the switch.
Old Nov 15, 2014 | 10:11 PM
CRiME's Avatar
CRiME
True, per the part numbers, they are the same. Will try that tomorrow and report back. Thanks for the reply
Old Nov 16, 2014 | 01:38 PM
CRiME's Avatar
CRiME
Problem solved with a phillips screwdriver. Door jamb switch was functioning, but loose. Tightened up, all is well
peterso2
Mar 25, 2019 11:28 AM
kavcheung
Jan 22, 2016 02:40 PM
flyng_fool
Sep 17, 2015 08:58 AM
xnick101
Intake and Exhaust
18
Sep 16, 2015 12:02 AM
