Newbie Here: Enhance sound w/o catback?
Old Jan 1, 2014 | 10:35 PM
e_squa's Avatar
e_squa
Nice pickup, you really aren't one to waste much time, those ARKs are a very nice quality set, and can't go wrong w/ that intake either. OK, you're like one day into your membership here, I'm really wondering what you're G is going to look like in a week or two~
I'm trying not to go crazy again with my new (used) car, but I acted quickly on my last one after purchasing it, and am following that trend again.
Only thing I feel weird about is I really don't want to lower my car again, so this will all be done on stock S suspension. Sound and tint in the coming weeks, but hesitant on rims.
Will it look weird not lowered? haha. I feel high while sitting in it, (compared to my old lowered RSX, but this car looks beautiful as is, from outside, and I'm tired of complaining about ride quality and clearances, and want to refrain from the extra thousands for what I'd want there.
As far as the R2C, it says here it's a CAI, not warm-air...
Infiniti G37 Cold Air Intake
Is that not the case?
Old Jan 1, 2014 | 10:49 PM
If you stick w/ 18s or 19s your G should look proper w/out a drop. Since you've already gone w/ a lowered ride and weren't thrilled w/ some of the compromises no need to go that route again. Plenty of nice wheel choices in the 18 or 19 size, and you could go w/ a nice staggered set of 18s or 19s w/ some aggressive rubber in the back so you can join us fat boys in this thread
https://www.myg37.com/forums/wheels-...fat-tires.html
Old Jan 1, 2014 | 11:11 PM
e_squa's Avatar
e_squa
Ok, tired of feeling "newbie" already, but have to ask... how do you "thank" someone (officially) on this board?
Old Jan 1, 2014 | 11:12 PM
lightlypurified's Avatar
lightlypurified
i paid a thousand dollars for a unique muffler from hks shipped from japan its called hks legamax i believe i am the only g37 with one it keeps that unique vq sound without dramatically making a huge sound. 87db
Old Jan 1, 2014 | 11:17 PM
The blue button on the lower right of the post you want to thank
Old Jan 1, 2014 | 11:23 PM
GoFightNguyen's Avatar
GoFightNguyen
Because Racecar
I'm trying not to go crazy again with my new (used) car, but I acted quickly on my last one after purchasing it, and am following that trend again. Only thing I feel weird about is I really don't want to lower my car again, so this will all be done on stock S suspension. Sound and tint in the coming weeks, but hesitant on rims. Will it look weird not lowered? haha. I feel high while sitting in it, (compared to my old lowered RSX, but this car looks beautiful as is, from outside, and I'm tired of complaining about ride quality and clearances, and want to refrain from the extra thousands for what I'd want there. As far as the R2C, it says here it's a CAI, not warm-air... Infiniti G37 Cold Air Intake Is that not the case?
Welcome to the forum, it looks like you've got some tasteful mods planned and on the way.
The r2c intakes sit in the engine bay and draw air through the existing air holes that previously conducted air into the stock air boxes. If you want to draw any more air than that, you will need to pull air from the engine bay itself. The motor runs hot on this platform, so you will be pulling at least some warm air in.
A "proper" cold air intake will actually have tubes extending outside the engine bay and behind the grille to pull cold (denser) air into the manifold. There's nothing wrong with R2C, it is an easy enough install, looks good, and has heat shields to mitigate the heat soak somewhat. However, in my humble opinion, a set of Stillen Gen 3 intakes will net you more horsepower gains. I used to have a set of K&N intakes and I was not pleased with the performance. I'm much happier with my Stillen setup now.
Old Jan 2, 2014 | 10:22 AM
That is not the case. Unless the air is sourced from outside the engine bay, it's a WAI. That said, no manufacturer is going to be successful marketing their product by calling it a Warm Air Intake. That would be silly.
The OEM air inlets are there, yes, as GFN just said. But the filter elements aren't in a closed system, regardless of the heat shields, so the air is being sourced from the immediate area. In OEM trim, those inlets are sucking air, they aren't scooping it.
All that said, don't worry about it. It's just an intake. Until you open the exhaust and get the car tuned, it's mostly a noise maker. A delightful one at that. You might notice in my sig line that I have the R2C Intake Kit, and I have zero regrets.
Here, this might be helpful to you for the install:
https://www.myg37.com/forums/g37-sed...s-learned.html
Old Jan 3, 2014 | 07:54 PM
guy from norcal's Avatar
guy from norcal
[QUOTE=e_squa;3719029]I'm trying not to go crazy again with my new (used) car, but I acted quickly on my last one after purchasing it, and am following that trend again.
yes perhaps for now.......but if you keep lurking on this site, you will start modding
Old Jan 4, 2014 | 08:53 AM
brizey's Avatar
brizey
Welcome to being grown up
I think the idea is a true CAI has to get air directly from outside the engine compartment.
Old Jan 5, 2014 | 11:35 AM
JohnnyD's Avatar
JohnnyD
I agree with you OP my other car is a Honda Prelude that is just slammed. Tucking wheel on coilovers. I just do not want to lower my G37! Look into the 19" OEM wheels off of the G37S coupe. I think they look nice and subtle. Looks fine without a drop from what I've seen.
Old Jan 6, 2014 | 01:26 PM
guy from norcal
thats what I said too...... then I talked myself into , maybe just a little drop would be ok
Old Mar 15, 2014 | 10:41 PM
rm2342's Avatar
rm2342
Originally Posted by KCMO
I'm going with z1 maf tubes, k&n drop in filters and removing the hood pad. Hopefully it'll growl a little more.
2nd step would be the tanabe axle back with oem tips.
But I'm looking for really subtle changes
How did the drop ins and z1 tubes work out for you? Interested in a similar set up also.
parkern
Oct 5, 2015 12:12 PM
G37sPhoton
Oct 4, 2015 11:08 PM
parkern
Oct 1, 2015 10:15 PM
ajosowiecky
Sep 30, 2015 12:15 PM
MrRiv
Sep 29, 2015 04:59 PM
