Sedan Chat Thread
Old Sep 8, 2022 | 04:27 PM
  #13981
Frankie Felber's Avatar
Frankie Felber
Originally Posted by hexotic
Theres an 18" wheel thread with lots of different examples of fitment and suspension setups for both coupes and sedans.
https://www.myg37.com/forums/18/2765...ic-thread.html
I also recommend looking at fitment industries galleries, its a good visual reference point for wheel sizing and fitment.
thanks bro, this helped so much!
Old Sep 8, 2022 | 08:01 PM
  #13982
4DRZ's Avatar
4DRZ
Originally Posted by thescreensavers
For the UCAs thats going from OEM rubber to spherical but I have also read that NVH hasn't been an issue with that switch.
My car is a DD 99% of the time but I plan to do 1-2 trackdays with some autocross.
​​​​​​I was looking at FA500s but since they raised the price with no benefits(covid) I have been looking at MeisterR GT1s which have double digressive valve (compression and rebound blow off at high speeds) think about curbs on a track.. etc. Alot of generic shocks don't feel good or do ride like crap. FA recommends 11k/8k and MeisterR recommends 10k/8k for my DD/Occasional track situation.
I do have equipment to see what the OEM springs are on my sport sedan but I'd need to take em off my car and by then it's too late I'd love to see what the OEM ride frequencies are.
I had a GR WRX with custom shocks that had Compression blow off which felt very good. And I've also had a car that has high speed comp/rebound blow off which also felt good. So looking for something in that realm.
One big reason for coilovers is to lower my car so I can fit more aggressive square wheels and tires for both DD and if I ever get a track set.
That makes sense. My UCA's were the Z1 race version with spherical bearings so I am familiar. No noticeable increase in NVH with those and that was with the Tein Basis coilovers.
Old Sep 8, 2022 | 09:19 PM
  #13983
backman_66's Avatar
backman_66
Thescreensavers, I may have some info about stock g37 sport sedan spring rates in my old thread about 370z nismo springs. I'm on my phone right now and don't feel like searching for it at the moment though.
Old Sep 9, 2022 | 05:51 PM
  #13984
FrogmanKouki's Avatar
FrogmanKouki
If you are still at stock ride hight then the aftermarket endlinks are not really needed. Only concern would be if they are failing, Someone correct me if I am wrong but that's not an issue. Reason for aftermarket endlinks that are adjustable is to remove any preload, If you are lowered that's when you need adjustment. Up to you just wanted to give you the FYI.
Since both bars are the same OD you'd need to find the wall thickness and hold positions to compare apples to aples, though Z1 does provide adjustment in the front.
Also another thought, you can see what people are SCCA Nationals are running but not sure there are many 370z's if any. At the end of the day just flip a coin both will be an improvement
Hotchkis
  • Specs: Front Sway Bar 35mm (1-3/8 in.) Hollow
    • +230% Stiffer than Stock G37
    • +205% Stiffer than stock G37S
  • Rear Sway Bar 28.5mm (1.125 in.) Hollow
    • 3 Way Adjustable
    • +130 185 260% Stiffer than Stock G37
    • +15 40 75% Stiffer than stock G37S
Z1 Swaybars
  • Bar Diameter
    • 35 mm Front
    • 28.5 mm Rear
  • Front Bar Stiffness (Over Stock)
    • Hole 1: 114% Increase
    • Hole 2: 165% Increase
  • Rear Bar Stiffness (Over Stock)
    • Hole 1: 138% Increase
    • Hole 2: 214% Increase
Thanks so much for looking up the numbers. I just finished installing Hotchkis sway bars front and rear. I've set the front to the softest setting and rear to the middle setting. Unfortunately I was unable to use a Z1 front bar as I have an AWD sedan. After a 10 minute drive the change is very noticeable, I'm looking forward to a longer drive.
Thanks for digging up the numbers - looks like the sweet spot would be Z1 front and Hotchkis rear.
The Hotchkis front bar is a teeny bit too stiff IMHO if you do anything else to the suspension - replace the shocks, get lowering springs, etc. Hotchkis + NISMO Z springs + Koni yellows + 19" wheels on an S Sedan = a little skittish in the front, on normal poorly maintained road surfaces at least. Good, fresh pavement it is *AMAZEBALLS*
I'm very thankful that our roads in middle TN are typically very smooth. Looking forward to this setup on a back roads drive here in a week or two.
Old Sep 19, 2022 | 10:25 AM
  #13985
rotarymike's Avatar
rotarymike
Moderator in Moderation
I'm going back to stock S springs on the rear, and non-NISMO 370Z in the front when I get a chance to work on the car. Keeping the Konis and Hotchkis. Hopefully will give a little more compliance in the front and a little more ride height in the back.
So... question is, sell the NISMO springs or put them in the racecar bin? I'm actively looking for a dead/ragged 350 or 370 to build a track car; not sure if NISMO springs would be good or if I'll have to go full coilover.
Old Sep 19, 2022 | 10:39 AM
  #13986
backman_66's Avatar
backman_66
I can't remember, which springs do you have in the rear currently?
I'm still on pre-2015 nismo springs front and rear and it's been great thus far, but the rear will sag if I put too much weight in the back, even with the spacers I added on top of the spring perch. Even a full gas tank makes it sag a bit so I usually run with 3/4 tank at the most. I never have any passengers in the back seat so I'm not too concerned though. I've considered going with swift springs or full coilovers if the need arises in the future (kids, maybe).
Old Sep 19, 2022 | 11:04 AM
  #13987
rotarymike's Avatar
rotarymike
Currently red Nismo (that's the earlier ones, IIRC) all the way around. Front drop is perfect, but man they're hard. Get really rattled on my crappy roads around here. The rears have 3/8" poly spacers under the bottom seat (split) and are the same chassis height as the fronts, but with the visuals of the rear being lower. I bottom out sometimes on highway bumps and would prefer a little forward rake, so I'm going to try the OEM sport springs again in the rear (no spacer). The 370Z non-nismo rates look softer than the Sport springs, and I think that would lead to a worse ride height in the rear.
I commonly have a 25# carseat and 50# kid in the rear seat - not enough to really cause sag, but the weight is there. Not much other than sunvisor and umbrella and a tiny safe (~2 lbs) in the trunk.
Old Sep 19, 2022 | 12:28 PM
  #13988
thescreensavers's Avatar
thescreensavers
So the 370Z Touring Sport is 55/45 1572 lbs rear. Compared to the Sedan is 3701 lbs (6MT) 53/47 1723lbs rear, (Coupe is 54/46) 1717 lbs rear, So is the issue with sagging related to extra 200 lbs and the larger butt?
If you are going for a track car build, then Coilovers is a no brainer being able to corner balance with you in the car is huge in itself.
Old Sep 19, 2022 | 12:36 PM
  #13989
I've got a friend visiting this weekend, bringing his new-2-him car... a 2013 BMW 135i 6MT M-Sport. (That's a long name.)
Everything I've read about this is that it's a fun little driver's car. Lightweight, 300hp, 6MT, RWD, and a smooth inline six. So I'm looking forward to seeing it.
Old Sep 19, 2022 | 12:38 PM
  #13990
rotarymike's Avatar
rotarymike
Cool. Nismo reds, anybody? Otherwise they'll be on ebay LOL.
Old Sep 19, 2022 | 06:08 PM
  #13991
4DRZ's Avatar
4DRZ
...and extremely easy to make power with. I met a guy with one of these at a track day a few years ago and he was on his low hp tune of only 730 whp!?!
Old Sep 22, 2022 | 10:54 AM
  #13992
For detailing spray, I've been using C.A.R. Products Bullet Proof Topper for a number of years now. Just bought a new bottle this morning, and thought I'd make the recommendation.
It works like all detailing liquids... mist on, wipe off. But this stuff leaves a wonderful shine, and the feel of the car's surface afterwards is amazing. Plus, it lasts longer that off-the-shelf detailing sprays. I don't apply it all the time, maybe every three washes, but it sure is a joy to use.
Old Sep 23, 2022 | 11:43 AM
  #13993
rotarymike's Avatar
rotarymike
Reminds me that I need to detail and clay bar mine before Z Nats. Well, or show up with it totally covered in mud to be the opposite.
Old Sep 25, 2022 | 01:09 PM
  #13994
My kid's 2014 Sentra started growling this morning with an exhaust leak. I got under the car and discovered the flange connections between the resonator and the muffler were disconnected. The bolts had sheared right off.
So with the hammer and chisel, I could break off the rusted nut on one of the holes, but couldn't break away the other. And the best I could do for now was put a big SS bolt in the one accessible hole. But just the one.
How long do you think one bolt can hang on?
Old Sep 25, 2022 | 01:41 PM
  #13995
JSolo's Avatar
JSolo
Just say no!!!!!
Can you drill the other one out?
