Sedan Chat Thread
Old May 24, 2022 | 12:54 PM
  #13816
BULL's Avatar
BULL
Moderador
Originally Posted by backman_66
I've looked at those z1 gaskets and may consider trying them if the normal gaskets don't seem to seal well. Thanks for the tip!
It will definitely be a good day once the install is done of the exhaust + pads + rotors. I'm looking forward to the lightened steering/cornering feel of removing that rotating weight. Will hopefully make the somewhat heavy G feel more nimble. I'm also planning to weigh the car after that because I've done quite a few weight reduction mods. I'm hoping to get real close to breaking 3500-3550.
I bought a set of HFCs that came with the Z1 gasket and though they were used they were good still. I didnt like the finish.
The cats I got (unsure on brand) had a factory style flange that accepted the donut so I went with the donut.
As for the rest of the flanges I used Mahle's gasket from Autozone. It's the best gasket you can buy and the price is great.
Old May 24, 2022 | 01:05 PM
  #13817
iCrap's Avatar
iCrap
While I have my car apart I ordered the whiteline diff bushings.... ready for another PITA job lol.
Does Z1 usually run memorial day sales? I'm considering getting better intakes as well while the car is apart. Maybe after that I can finally get it tuned.
Old May 24, 2022 | 03:24 PM
  #13818
Guys, this is a weird one. You know I've been whining about my AC being weak. Well today my kid was in the car, and she asked me to turn down the AC. Apparently it's only weak on my side of the dashboard.
WTF is that all about? I'm getting full fan, just not the same kind of cold air.
Old May 24, 2022 | 04:14 PM
  #13819
JSolo's Avatar
JSolo
Just say no!!!!!
You have multizone temp control? Both sides set to same temp (sync)?
How about heat? One side gets hotter than the other? Blending/mixing door issue?
Old May 24, 2022 | 04:15 PM
  #13820
iCrap's Avatar
iCrap
Ok, so it's the blend mechanism used for the dual climate control then. It must be stuck.
Old May 24, 2022 | 04:28 PM
  #13821
Now we're getting somewhere! Yes, I have dual zone climate control. Hmmmmm. I think we all do, don't we?
iCrap, do you know where that mechanism lives? I wonder if getting it "unstuck" is a lubrication, or a new part.
Old May 24, 2022 | 05:38 PM
  #13822
iCrap's Avatar
iCrap
Unsure on these cars, since thankfully mine has not had issues yet. It should just be a matter of lubrication. There's probably a section for this in the fsm. Hopefully not too much disassembly required.
Old May 24, 2022 | 10:10 PM
  #13823
BULL's Avatar
BULL
Moderador
It lives in the forsaken zone
Inside of the heater box, whole dash, heater hoses and crash bar need to be removed.
Did you ever get the pressures checked?
Old May 25, 2022 | 05:41 AM
  #13824
Oh geeze, I'm not going to do any of that. Yikes.
No, other than the recharge gauge telling me I was at proper pressure already.
Old May 25, 2022 | 09:20 AM
  #13825
rotarymike's Avatar
rotarymike
Moderator in Moderation
If the seller can ever ship me the 2.5 INNER diameter pipe I ordered, I'll have my long tube cais with R2C filters up for sale. See build thread for pics.
Old May 25, 2022 | 09:59 AM
  #13826
ILM-NC G37S's Avatar
ILM-NC G37S
...the problem then points to either a mechanical issue (possibly, the TXV) or a control (electronics) issue (blend door(s), temp sensors, trim value, etc.).
Rochester, depending on how much the issue bothers you, you might be able to access the driver side temperature blend door motor from under the dash. On the "climate box" there are four motors that modulate the different doors to achieve the desired output (fresh air, mode (vent, floor, defrost), and the two (2) temp blends (driver/pass):
(sample images taken from ebay/web)
For the driver side, you can remove the motor and check that the blend door moves freely. Any sticking or binding and you'll know for certain. You can also "cycle" the motor to make sure it is working fully. Though very rare, these motors do fail.
Either way, unless the blend door is seriously stuck you will not have to remove the climate box to diagnose/ repair.
Old May 31, 2022 | 11:02 AM
  #13827
BULL's Avatar
BULL
Moderador
On another note XM radio is free for the next month.
Old May 31, 2022 | 12:24 PM
  #13828
Selym's Avatar
Selym
I did a three-month free trial years ago, and I'm still able to listen via the app on my Roku player. I'm not sure if it's an oversight on their part, or by design.
Old May 31, 2022 | 12:30 PM
  #13829
If it's worth it to you, satellite radio is fine whatever the cost. However, don't think you can just "cancel" the service if you want to move on, regardless what they say. You keep getting billed, they make it impossible to connect with someone who will just close the account. You actually have to start keeping a record of the calls and events in order to make your case. It's nuts. They're worse than the cable company.
Old May 31, 2022 | 12:47 PM
  #13830
abrecos's Avatar
abrecos
it takes me four hours on phone with XM Sirius representative to cancel finally my subscription. I'll tell him that I selling my car and he still harassing me with probably another 200 offers until giving up and cancel my account. Never ever again. I have the Tidal for 10 bucks a month HiFi and sound quality is outstanding.
