Sedan Chat Thread
Old Aug 2, 2021 | 11:26 AM
  #13591
hexotic's Avatar
hexotic
DIY Cheapskate/Mod
Originally Posted by SonicVQ
Good find!
However, "buttons"??? I didn't know my car had buttons
​​​​​​I'm assuming it's the pedal sensor buttons that are revealed when you press in the pedal. That's how you do a burnout in our cars too, by holding the brake button.
Old Aug 2, 2021 | 11:30 AM
  #13592
SonicVQ's Avatar
SonicVQ
Understood... just having a little fun. Good video as it shows that the clutch and brake switch can cause this issue.
Old Aug 2, 2021 | 05:52 PM
  #13593
rotarymike's Avatar
rotarymike
Moderator in Moderation
Intermittant switches, either on the clutch/brake pedals OR in the steering wheel, make more sense than other failures. Unless the clock spring has a few contacts that are iffy.
Old Aug 9, 2021 | 10:48 AM
  #13594
rotarymike's Avatar
rotarymike
Anyone have a fast-shipping solution for OEM infiniti parts? I need front shock boots (the bellows with the bump stop) as my bump stops are disintegrated. Yay broken parts found on disassembly. Car is on stands and as it is. I'm ubering to work this week.
Local Nissan dealer wants $75 each for the 370 version and $65 each for the G37 version and can't get either this week. PN 54050-JK51A for 370. 54050-JK01A for the G. This is going on Konis with 370Z Nismo springs so I'm assuming the 370 version will fit too.
Unless the generic-ish KYB 92771-05043484 will fit - anyone know?
Old Aug 9, 2021 | 11:31 AM
  #13595
iCrap's Avatar
iCrap
I used autoanything for parts before, they had it to me the next day. RockAuto can also be pretty fast. But for stuff where my daily is down... I usually just bite the bullet and go to the dealer parts counter.
Old Aug 9, 2021 | 12:28 PM
  #13596
rotarymike's Avatar
rotarymike
The Infiniti dealer called me back and had the price more in line with what I'm seeing online (for OEM parts). Won't have 'till Wednesday though
No one else local has anything at all, and delivery seems to be between next week and the week after. I'll check autoanything.
Old Aug 13, 2021 | 10:44 AM
  #13597
rotarymike's Avatar
rotarymike
Putting the car back together - whats the torque for the lower control arm steel bracket (the one that is on the nut-side of the shock mount bolt/sway bar link?
It doesnt show as removable in the FSM.
Old Aug 13, 2021 | 11:34 AM
  #13598
2.2Lude's Avatar
2.2Lude
120ft lbs is what I used when I installed my coilovers.
Page 8:
http://www.370zcoupe.com/ACCS/1TK27.PDF
Edit: Reading comprehension fail. I couldn’t find the specs for those 3 bolts either so I just tightened them to what I felt was good.
Old Aug 13, 2021 | 11:45 AM
  #13599
rotarymike's Avatar
rotarymike
Yeah, the FSM shows 120 for the strut mount/sway bar link. I'm talking about the three 14mm bolts that hold the steel plate on to the aluminum control arm.
Stolen from https://infinitig37.com/infiniti-g37-BC-coilovers.html
Old Aug 14, 2021 | 12:51 PM
  #13600
Yikes! I just accidentally moved this entire thread.
Then I moved it back. Such a moderator newbie... LOL
Old Aug 14, 2021 | 08:30 PM
  #13601
rotarymike's Avatar
rotarymike
Yeah, I finally went with 40 ft-lbs... about what I'd expect for a bolt that size. I've got a clunk when driving, but I think it is either the strut tops or one of the swaybar links I *maybe* forgot to tighten. After losing almost 7 pounds from sweating, the wrapping-up portion of the day is a little fuzzy.
If it's a strut top, I need to make a tool. I have an offset 19mm I made for konis/tokiko illuminas/KYB AGXs on the RXs... figures this one is 17mm. No parts stores have anything useful, so I'm back to finding out if my ancient mig welder still works LOL.
edited: here it is:
This was a 10-minute use-once tool I built... almost 20 years ago LOL. Shame it's 19mm and not the 17mm I need for the Koni's.
Old Aug 22, 2021 | 10:46 AM
  #13602
CPJ LB's Avatar
CPJ LB
What's up guys!! I haven't posted in a while, but have been lurking... I have done some more modding to my '12 G37X and wanted to share the recent upgrade.
I was experiencing some trans issues - more specifically, the torque converter....I ended up having the car sent to Level 10. After speaking with Level 10, they ran a complete diagnostic test on the TC and Trans...it was deemed that the trans was on it's way so it was only a matter of time. I ended up getting the complete Level 10 transmission done - "Bulletproof 7spd transmission upgrade". I must admit, the car drives flawlessly and no more shifting issues. I can truly feel the power throughout the shifts and the car pulls. I have hi-flow cats on order, so it'll be interesting to see what my upcoming retune will yield.
Old Aug 29, 2021 | 02:35 PM
  #13603
2.2Lude's Avatar
2.2Lude
Originally Posted by 2.2Lude
Opinions on this lip? It is a Autokits prototype lip that never went into production, from my understating, for the OEM G37 Sport bumper. After a little bit of digging around haven't been able to find any other examples of it online, making it rare with possibly just a few testers ever being produced.
So while messing around looking for vented hoods I came across pictures of this lip on the Autokits demo car. These do a much better job of showing the lip fitted to the car, as a bonus it’s also a white G.
Old Aug 30, 2021 | 12:49 PM
  #13604
rotarymike's Avatar
rotarymike
Damn, that hood is sharp.
Old Sep 2, 2021 | 10:04 PM
  #13605
Rich11G37xS's Avatar
Rich11G37xS
is there a way to "re tighten" the emergency brake pedal....mines a little loose and it wiggles a little bit and causes the system to beep annoyingly, implying the brake is on
