Sedan Chat Thread
Old Apr 24, 2020 | 05:13 PM
  #13381
rotarymike's Avatar
rotarymike
Moderator in Moderation
Two ideas.
Cheaper, faster: get some teflon pipe thread sealant - the plumbing stuff. Put on the top 1/4" of threads.
Slower, more permanent - get a threaded plug (IE slug of metal that is all threads, probably can get a metric thread pipe plug from mdmetrics etc) and grind it down to size so that when you're turning your shift **** on, it bottoms out pointing in the direction you want it to point (if yours is directional, which IIRC it is not). Basically you want it to stop at a point that isn't all the way up to the top of the cavity in the ****.
Old Apr 24, 2020 | 06:25 PM
  #13382
Teflon thread tape... that's interesting. Thanks, Mike.
Old Apr 24, 2020 | 06:43 PM
  #13383
rotarymike's Avatar
rotarymike
The best answer is still the threaded plug. Something like this:
Amazon Amazon
(although obviously not 100 of them.)
You can add small washers on top of it to get it to sit in the **** threads where you want, and when the shifter stalk hits it it will tighten up nicely.
Suppose I should list my short shifter on the forsale page.
Old Apr 24, 2020 | 06:45 PM
  #13384
iCrap's Avatar
iCrap
On my S2000 i used a jam nut at the bottom, and cranked that down. I also covered it up with the shift boot so you can't see it. Don't know if that works on the G shifter though.
Old Apr 24, 2020 | 06:49 PM
  #13385
rotarymike's Avatar
rotarymike
You could also get one of these: DEWHEL Shift **** Boot Retainer/Adapter for Manual Gear Shifter Lever 12X1.25 (Black)
Amazon Amazon
Old Apr 24, 2020 | 06:52 PM
  #13386
I like the tape idea. Easy enough to experiment with.
This is the ****, BTW, six years later and still digging it.
Old Apr 24, 2020 | 07:00 PM
  #13387
rotarymike's Avatar
rotarymike
Never been a fan of the all-metal ***** - I live in the South and it gets intolerably hot. Like, burn and resulting scar hot. Even the textured ones like the Flyin' Miata voodoo *****.
This looks interesting though: https://hackaday.com/2018/06/16/tita...ind-our-gears/
Old Apr 24, 2020 | 07:11 PM
  #13388
I don't have issue with it in the summer in Western NY. It rarely gets that hot, it's like 99% garage kept, and when it isn't for whatever reason then I use a sun shade.
Winter, however... OMG, it's so cold it's unusable. So I use a different **** during the winter.
Old Apr 25, 2020 | 12:00 PM
  #13389
rotarymike's Avatar
rotarymike
I *wish* I could garage mine. Our home builder must have gotten a discount on 7' garage doors (standard is 8') so with the boxing in on the sides we have just a little over 6' width. All the similar homes in this development are like this. My wife's CX5, if we fold her mirrors in, will fit with about 1.5" clearance on each side - not enough that either of us felt comfortable putting the car in there. Haven't even tried with the G.
On our long-term todo list is to get into the header area over the garage doors and see if it is a steel beam across (we think so, no center pole in the garage like some others) and then we can convert to just one large garage door. Or one large and one small like a motorcycle door for the bikes and outdoor activity stuff (IE canoe & kayak).
In the summer sun, even with a sunshade I usually see inside temps of about 120. Without sunshade 140. With leather, contrary to the weather I usually don't wear shorts
Old Apr 25, 2020 | 02:01 PM
  #13390
I'm discontent with my garage, too. It's a detached, two-car, with enough width that one side or the other can fully open their doors, but the wall side for each is tight. Do-able, but really tight. The cement floor is cracked and heaving and breaking apart. And it's unheated.
But I make the best of it. Don't have any choice, except to move.
Old Apr 26, 2020 | 11:34 PM
  #13391
Kossac's Avatar
Kossac
is this a stock front bumper?
Old Apr 27, 2020 | 07:43 AM
  #13392
4DRZ's Avatar
4DRZ
I think you have a pretty similar climate to me in WI so I can see you needing to switch that in the winter. For me it would be unbearable in the summer too because my car sits outside at work all day and it would get scalding hot.
It is funny how something so commonly overlooked can make such a difference in the driving experience. I have tried a number of shift ***** in this car and always thought that lighter was better (because race car), but this is the one area where a heavier weighted **** shifts so much smoother. A while ago I finally decided to try a Raceseng Sphereology shift ****. It matches the interior perfectly, it is heavy so it shifts really well, and it has an interchangeable (for different colors) delrin surround so it never gets too hot or too cold. So far it is my favorite shift ****. You can also customize the engraving on top in case you want something different.
Old Apr 28, 2020 | 02:49 PM
  #13393
rotarymike's Avatar
rotarymike
Yeah, the heavier the better. It's why I like Razo ***** - a relatively inexpensive Japanese brand, limited US availability and a touch more expensive here. BUT - they label their ***** by weight. So I have a 240g round leather-covered ball now, and a 300g one to go in when I'm done with interior stuff (new one matches stitching of the car). $20ish in yen, $45-60 here.
My first track car was a 1st gen RX7, which have atrociously long shift throws. I used a different shifter lever (same trans, different car chassis) to get it closer to the steering wheel, and put a wooden round ball on it. SUPER hard to shift. Put a heavy ball on after my first trip to Japan and totally changed the car - shifting was now something I didn't have to think about to get it right.
Old Apr 28, 2020 | 02:57 PM
  #13394
My titanium **** is 450 grams.
Mike, if you've never seen this video I made years ago... anyway, this:
Old Apr 28, 2020 | 03:01 PM
  #13395
rotarymike's Avatar
rotarymike
Showoff LOL.
