Sedan Chat Thread
Well, shoot... then you have to start asking yourself, why did the substrate come apart inside the cat? There really are no good answers there.
I don't know what could've caused it. I don't remember hitting any bad potholes on recent weeks. This really makes RFHC tempting.
I'm no mechanic, but that's my thinking. See what other kind of input you can get as to why a 3-4 year old catalytic converter would start rattling.
Yes, but resonated... that means Fast Intentions and an 8-week wait, because they build to order.
Which is precisely why I replace parts before they're even remotely close to needing it... LOL
Sorry. Just muddying the waters...
Rochester makes an excellent point...that's too early. We can probably all relate many instances where cats were good for 100K miles or more. There must have been an issue, code or indication why the guts are destructing. Shields, yes, internals? Hmmm...
Sean
Sean
Sean
Sean
I might just check it out for myself when I get my car up on a lift for an oil change. I'm not sure if they actually tried to clamp down the heat shield and decided to jump to conclusions by saying the cat is bad. The car still drives fine, I've had zero issues, even on my 9+hr drives from NC to NJ.
Sean
Yes it will fit ok, the piping diameter is bigger going into the rear mid pipes so there may be a bit more noise generated from that mismatch. Would be best if you plan on an aftermarket exhaust down the road. There's also a good chance you could find an OEM Ypipe in our classifieds if you post a WTB (want to buy) thread over there. Oh, and welcome to the site, I believe you have to have 5 posts and wait a couple days to post classifieds though, maybe just a search over there will find you one??
Private Classifieds - MyG37
Edit~here's one
https://www.myg37.com/forums/private...nd-y-pipe.html
Edit~here's one
Thank you Adrian ! oh I know, believe me, that's why I specifically asked the guy to shape them that way as that's something I wanted from the beginning.
Is that weird that even though I only had the steering wheel for a day after I installed it and I said the same thing as your wife? Feels like the single best mod I did to the car, can't wait to pick up my sedan from the dealership tomorrow or the day after tomorrow, while I'm driving this boring Q50a...
Nice to see your dealer covered this under warranty. I believe since it is an emissions related item that Infiniti actually extends the warranty by another year (5 years instead of 4).
Bad CAT's are not all that uncommon. I've run across it many times. Most common cause is that the matting inside the CAT fails to expand properly when the car/CAT is new and therefor never properly holds the ceramic brick in place. Eventually the brick will start to move around and then begin to rattle.
G37 Sedan *Chat Thread*
Leatherette seats, no heated seats, no nav, no power mirror, idk what else it's missing since I'm not very well aware of what other Q50's have with better packages.
Also speaking of dealerships covering stuff under warranty, they found the water leak on the passenger side making the carpet wet caused by a clogged sunroof drain and also replaced or are still replacing my rear subframe bushing which has been leaking for a while now all under warranty as well, hence maybe why they still haven't called me today with an update, probably keeping it till tomorrow if they got the part late today. Can't wait to get back in my sedan finally...
