Sedan Chat Thread
Old Jan 8, 2014 | 02:09 PM
  #841
RexHavoc's Avatar
RexHavoc
Yes, yearly. OBDC readings and visual inspection, but they don't sniff. IDK who does anymore, because lots of states phased that out. California, maybe?
FI cats would pass the visual inspection, because well, it looks like a cat and "there it is", but not if the visual inspection was looking for the appropriate stamp on the cats. That's the part that has me concerned.
There's no "stamp" on the side of these cats AFAIK, other than the rather obvious branding, which I think I'll sand off:
May not have to, IIRC mine didn't have that branding on them.
Old Jan 8, 2014 | 02:20 PM
  #842
connoisseurr's Avatar
connoisseurr
All new members in the Sedan Chat Thread need to go to the original post and thank Elohel, even though he hasn't posted here in three weeks... just because it's fun to see how many *thanks* can be collected on a single post.
I think he's pissed off at his G, at the moment LOL. It does not like the cold weather in his climate.
I talked to Tony at FI - some get branded and some don't. As they're trying to roll out sets of these, some take the time to press the brand and others don't.
Old Jan 8, 2014 | 03:12 PM
  #843
Does anyone here actually have their OEM cats handy? Wondering if/where there is a CARB "stamp" on them.
Sometimes I feel like I'm wandering into nonsense, completely misinterpreting things.
Old Jan 8, 2014 | 03:21 PM
  #844
RexHavoc's Avatar
RexHavoc
John I have in a box at home. I'll take a look and post some pics later if you still need them. This will ensure I actually pick them up and get them out of the dining room so thank you.
May be a little late, I need to try and deliver some headlights, finish installing my flappy paddles and try to get the engine bay covers off tonight.
Old Jan 8, 2014 | 03:48 PM
  #845
Awesome. Thanks, Rex. I think it would be useful and informative to see close up pics of the OEM cats.
...and try to get the engine bay covers off tonight.
What?
Old Jan 8, 2014 | 04:38 PM
  #846
warped ideas's Avatar
warped ideas
A quarter past stripped
Me to, me to. I'll check out mine late tonight when I get home. It may be hard to see any stamp though.... They are covered almost entirely by the (welded on) OEM heat shields. I'll check for you. Maybe we can all compare numbers if there are any.
Old Jan 8, 2014 | 07:17 PM
  #847
Don't you guys know the NSA is watching your every move, I'm sure they'll be relaying all this info to Johns' smog shop ASAP
Old Jan 8, 2014 | 07:23 PM
  #848
warped ideas
They'll never take me alive!
Old Jan 8, 2014 | 07:34 PM
  #849
Robert_K's Avatar
Robert_K
As soon as the Global Warming nut jobs that got stuck by the ice in Antarctica admit my exhaust isn't increasing the earth heat and it's the star that has been warming the world for billions of years (the sun)… I'll care about smog.
Maybe if the DOT cared more about the asshats driving around with two lug nuts on one wheel and not about our highly maintained, cat-less, cars.
Old Jan 8, 2014 | 07:53 PM
  #850
warped ideas
I second that! I actually witnessed an entire wheel fly off a car once.... I couldn't believe my eyes.
Old Jan 8, 2014 | 09:12 PM
  #851
connoisseurr
Does anyone here actually have their OEM cats handy? Wondering if/where there is a CARB "stamp" on them. Sometimes I feel like I'm wandering into nonsense, completely misinterpreting things.
There are no markings on the bottom of the cats, however there is a marking "AQ" on the top of the cat heat shield. It can only be seen when they are removed from the vehicle however.
Old Jan 8, 2014 | 09:24 PM
  #852
gsm026's Avatar
gsm026
In the Colorado Front Range counties we have:
- Visual inspection on the ground (mirror on pole, restrictor check on gas fill. They are only looking for presence of converters, I believe.
- Check for codes on OBDII.
- Emissions at idle and under load on a dyno.
Ours is only required starting 4th model year after new, and every 2 years thereafter.
Old Jan 8, 2014 | 11:53 PM
  #853
kOrE's Avatar
kOrE
Quick question. I just realized that the smaller light within the headlight is on when my regular lights are on. I thought they were the high beams. . . but apparently they are not. Is this the normal setup?
Old Jan 8, 2014 | 11:55 PM
  #854
GoFightNguyen's Avatar
GoFightNguyen
Because Racecar
My headlights are different, but I believe those are your "city lights" there should be a setting on the turn signal lever that illuminates only the city lights. It's similar to DRL's.
Old Jan 8, 2014 | 11:57 PM
  #855
kOrE's Avatar
kOrE
Hmmm, I think your right. I have been messing around with the settings lately and I don't recall seeing those lights on. Now the tricky part, how to undo whatever it is that I changed, lol!
