Sedan Chat Thread
Old Nov 15, 2015 | 11:18 AM
  #8161
Lego_Maniac's Avatar
Lego_Maniac
Cant you run a square setup on the duckfeet? I wouldn't think the 1/2" in width would make a difference.
Old Nov 15, 2015 | 11:38 AM
  #8162
Lego, you're thinking 1/2" stagger on the Coupe. The Sedan Sport rims have a 1.0" stagger: 7.5" front, 8.5" rear. Heck, you know that, man.
When I bought my snows years ago, only Bridgestone offered OEM size for the rear, and I wasn't inclined to stretch. Since then, Michelin has stepped up with their X-Ice. I've also learned since then that these performance snows from Bridgestone are good at neither performance or snow.
I've thought about finding someone to swap my 8.5" rears with, but since these are just snows now... meh. Too much money and effort.
Old Nov 15, 2015 | 03:55 PM
  #8163
Mik3G37S's Avatar
Mik3G37S
Yes you can, I have 245/45/18 all around winter performance tires on my duckfeet
Old Nov 16, 2015 | 09:21 AM
  #8164
MaQG37's Avatar
MaQG37
Any 6MT owners sit in a automatic G37S? I feel the seats in that car can go lower than ours. I was driving my GF's car yesterday and I feel the seat can get so much lower giving my more headroom.
Old Nov 16, 2015 | 03:13 PM
  #8165
MaQG37's Avatar
MaQG37
Originally Posted by CPJ LB
projector lens project....I'm still undecided to whether or not do the clear lens swap myself (OE to STI-R clear lenses) or have a company do it... ONEighty or Lightwerkz. I've seen many guys here use ONEighty, but haven't seen any reviews on Lightwerkz (they're in NJ)
Anyone care to share their experiences with either...DYI seems pretty straight forward, but I just don't have a lot of time to dedicate to it....also what would be a legit price towards having the lens swap done professionally? thanks.
I've helped a member here with part of the project about a month ago. I would say the clear lens is definitely worth it. The project isn't difficult, just very time consuming and an extra set of hands is very helpful. Prying the headlights apart is probably the most difficult part along with spacing out the clear lens. You will need an extra long phillips screwdriver to remove the clear lens. I'd also advise firing up the projector and checking out the cutoff before sealing everything back up.
Old Nov 16, 2015 | 03:23 PM
  #8166
CPJ LB's Avatar
CPJ LB
^ thanks! I agree about the clear lens swap...it really makes a difference.
too little time for all the mods on my 'to do' list
**EDIT***
I moved my original post in another thread - "OEM vs Aftermarket HID..."
Old Nov 16, 2015 | 09:19 PM
  #8167
Knightjs's Avatar
Knightjs
Got a 2011 G37S, bought used last year. Rotors were warped but no big deal. Have gotten tired of it now.😠 Still have 6-7 mm left on pads. Had Kauffman Tire turn the front rotors today. I put on new Stop Tech pads and bedded them according to their recommendation. Still have vibration when braking. Kauffman says it felt like the rear rotors were warped when they tested it. But I can't recall ever having warped rear rotors on a car. Should I have them turned? I have new pads for the rear but haven't put on yet. Any ideas?
Old Nov 16, 2015 | 09:37 PM
  #8168
Originally Posted by Knightjs
Got a 2011 G37S, bought used last year. Rotors were warped but no big deal. Have gotten tired of it now.�� Still have 6-7 mm left on pads. Had Kauffman Tire turn the front rotors today. I put on new Stop Tech pads and bedded them according to their recommendation. Still have vibration when braking. Kauffman says it felt like the rear rotors were warped when they tested it. But I can't recall ever having warped rear rotors on a car. Should I have them turned? I have new pads for the rear but haven't put on yet. Any ideas?
Might get them checked for runout, might also be uneven pad deposits. The majority of rotors that seem to be warped are more often pad deposits. Rear rotors are solid so less of a chance that they're warped since they don't take the majority of the brake duty. Might just try some steel wool or scotchbrite pad and scrub the rotors and see if the problem goes away or at least improves.
Old Nov 17, 2015 | 12:37 AM
  #8169
AroundTheG37's Avatar
AroundTheG37
Welp, sold the car. Got an interesting game to play and the winner will get a brand new cabin air filter that I never installed if they pick the car I bought.
Details.
Under 35k (barely).
Color is white and the car is used.
Must pick exact model.
Hint : manual trans of course and quite the handler (even for a heavy car).
Good luck and will answer later in the afternoon.
Old Nov 17, 2015 | 12:47 AM
  #8170
Mik3G37S's Avatar
Mik3G37S
Details.
Under 35k (barely).
Hint : manual trans of course and quite the handler.
Gotta give us more than that, either domestic or import or V6 or V8 ? c'mon I need that cabin filter been 44k miles and never got to replace mine
Old Nov 17, 2015 | 12:49 AM
  #8171
pledes23's Avatar
pledes23
Details.
Under 35k (barely).
White Audi S4
Old Nov 17, 2015 | 12:53 AM
  #8172
AroundTheG37
Ok, one more, v8.
Old Nov 17, 2015 | 01:57 AM
  #8173
Epiphany's Avatar
Epiphany
Details.
Under 35k (barely).
E92 M3? Camaro ZL1?
Old Nov 17, 2015 | 03:08 AM
  #8174
Baby Jumpman's Avatar
Baby Jumpman
2014 Camaro ss
Old Nov 17, 2015 | 06:14 AM
  #8175
Lego_Maniac
Boss 302.
