Sedan Chat Thread
Old Jul 2, 2015 | 01:52 PM
  #7111
pledes23's Avatar
pledes23
G37 Sedan *Chat Thread*
RJM Clutch Pedal Assembly... paid in full and shipping today.
370Z & G37 AFP Clutch Pedal Assemblies - Â*RJM Performance.com
Sign me up for that test drive in August!! Looking forward to your impressions of it.
Old Jul 3, 2015 | 01:17 AM
  #7112
twin_snails's Avatar
twin_snails
Yes I have SPC rear camber kit that was installed orionally when rims/tires went on. After much more research with my alignment sheets from before...I was running -3 camber so the wear is a no brainer there....but the 5k miles is still a concern imo. At this point I will never regret going 20's, even though a 19" would have allowed for a much better fit spec wise. I am down from the 295/30's to a 275/30 in the rear now and my camber is at -1.7 so I should see a nice increase in wear and life of the tires. I HOPE
I can see how the -3 would affect the wear. It doesn't much matter if the tire has a treadwear of 600...you'll still see very premature wear with high negative camber. Many moons ago in my Discount Tire days, I'd have BMW M3's come in and they'd wear through the rear tires very very quickly. BMW's of that era were notorious for running a lot of negative camber stock from the factory on the rear tires. I guess when they call it the ultimate driving machine, it comes with an expense because it was known as the ultimate tire chewing machine. Look at the picture of this stock X5 and you can see just how much they run. Matter of fact, next time you roll up on an X5 M with the giant gumball tires in back, you'll see the same thing.
Did you do the camber and the toe bolt? -1.7 should help out a lot. You've almost added 50% more camber so hopefully that will do the trick. If I recall correctly, stock camber is between -1.1 and -1.4 so you're barely outside that range.
My suspension is at stock height and when I went to 19's with the 275 rear tires, I got more inner wear than I did with the stock tires.
Old Jul 4, 2015 | 01:26 AM
  #7113
Mik3G37S's Avatar
Mik3G37S
Originally Posted by connoisseurr
Eggcellent. I will be test driving in August lol.
Me three! whether I get mine before or not I'll be test driving in August as well lol
Old Jul 6, 2015 | 08:06 AM
  #7114
Daddy Fat Sacs's Avatar
Daddy Fat Sacs
That is a CRAZY pic and now thanks to you ill be looking at alot of beamers this way. I do have to say...and as expected....but now my car feels a hell of alot more planted then before. Def harder to break the rear loose
Old Jul 6, 2015 | 10:51 AM
  #7115
nelledge's Avatar
nelledge
n00b
Originally Posted by MaQG37
looking forward to your review! I'm sure Nelledge will too.
Hahaha. Thanks for making it sound like I'm a creeper, MaQ. I've been studying this forum with G35driver for days since I finally pulled the trigger on a G. Voyeur more than creeper.
The clutch pedal mod is high on my list. I'm on the fence, but barely. I just need a little tap, and I'll order it.
Old Jul 6, 2015 | 11:12 AM
  #7116
Assuming the RJM Pedal is a keeper (safe assumption), you're welcome to have my jsolo return spring. I'd be happy to pay it forward, nelledge.
Baby steps.
Old Jul 6, 2015 | 11:57 AM
  #7117
ttv36's Avatar
ttv36
Race, repair, repeat.
Originally Posted by VQ-Vic
Yea, its a pretty good deal. And I do like the style of these.
So the specs.
FR= 19x9.5 +40
RR= 19x10.5 +23
FR= 245/40/19
RR= 285/35/19
I do know I will have to run stretched tires, but I have no idea what the safe margin would be. I've been using this Custom rims, wheel tire packages for your ride - RIMSnTIRES.com won't let me input stretched tire specs.
Rollin/pullin fender and small camber will have to happen. But I want to make sure my transfer case doesn't explode.
Sorry I am like a week late, but I think that is a bad choice in wheels because you will have to modify the rear and/or stretch with negative camber to fit. Then your rear would be so far poked that you would need a 15-25mm spacer to match the look in the front.
I understand rolling the inside fender lip on cars that only have that 90* bend in the sheet metal, but thats not the design of the G last I looked. Maybe I'm not following your intent.
Pulling the fender, though... How do you do that without fabricating an extension to the fender?
Fender can be pulled, the hard part is being able to keep the bend line smooth and visible from the side - I had to have my body shop do this for me.
Here is my fender after I pulled it:
After being smoothed out by the body shop:
Old Jul 6, 2015 | 12:24 PM
  #7118
Thanks for the pics and explanation, Tony.
So to sum out... the G's rear fender can be pulled, but only looks good after body work.
Old Jul 6, 2015 | 01:10 PM
  #7119
ttv36's Avatar
ttv36
^ Perhaps if they are pulled by a professional/someone who has a lot of experience pulling fenders then they might look decent. But since I knew the car was going to the body shop for the kit to be installed I pulled them myself just to have the experience. The fenders definitely looked like bacon from the side when I was done!
Old Jul 6, 2015 | 03:51 PM
  #7120
twin_snails
Yeah I have kind of noticed that over the years. Most bimmers usually have more negative camber in the rear than compared to the front. The idea is that when cornering, the tire camber angle gets more perpendicular to the road surface to maintain more contact with the road. But I'm not usually cornering that hard so for me, it wouldn't help much.
I'm glad to hear that you've got it sorted out now and it's definitely a good feeling to have the car feeling planted.
Old Jul 6, 2015 | 09:34 PM
  #7121
Lego_Maniac's Avatar
Lego_Maniac
My car got a lot of love today.
With a 2 and 4 year old I don't get a lot of time to mess around with my car. But I had today off for the holiday--instead of last Friday--, and while my wife had the day off too, she opted to work her new job most of the day (way to double dip baby!!), so I had time, with no kids, to mess around with my car.
Changed the oil--Red Line 5W30, Purolator PureOne filter
Washed the car, then spray waxed her
Vacuumed out the interior and wiped everything down. Cleaned and conditioned the front seats
Finally installed the happy buy it now extreme roof spoiler
I got a bunch of other stuff done today too. Winning
Old Jul 6, 2015 | 09:46 PM
  #7122
Orly? Where's the proof... I need proof.
Old Jul 6, 2015 | 09:48 PM
  #7123
Lego_Maniac
No pics, yet.
I instead chose to take an hour long walk through the neighborhood and interconnecting trails
Old Jul 7, 2015 | 05:39 PM
  #7124
ChinkyChoy's Avatar
ChinkyChoy
Ok guys I need your help cause my brain is absolutely fried at this point. I am looking into a new set up and most likely my last one (promise) I got some changes for the G to include an Air set up as well so that's why I m looking for a more aggressive set up.
My current set up is 19x9.5 +25 245/40 all around
Potential new set ups:
19x9.5+14 high disk
19x9.5+17 low disk
19x10+20 high disk
19x10+24 low disk
20x10+33 high disk
20x10+24 low disk
20x10+20 high disk
20x10+11 low disk
20x10+20 high disk
20x10+24 low disk
Thanks!
Old Jul 7, 2015 | 10:15 PM
  #7125
MaQG37's Avatar
MaQG37
Anyone with sport seats have some squeaking when taking turns ? It sounds like it's coming from the rails.
