Sedan Chat Thread
Old May 4, 2015 | 12:08 AM
  #6661
Mik3G37S's Avatar
Mik3G37S
Believe it or not this was taken with a galaxy s5 and google photos enhanced to try and show it how I see them. They were powdered coated by www.powder-coated.com
On car they look like the typical brembo red you see on srt8's.
John, the price was not for removal or reinstall. I had to do that part myself which is pretty easy...unless you drain all the brake fluid and get air in the system like me
My bad yes I see they were powdercoated, somehow I left that part out of the loop, yeah I wish my calipers looked the same in pictures as they do in person! That color looks great at least in pictures, looks almost like candy red!
Yeah mine came out to be $250 with removal and install and then additional $75(just the cost of stripping the bad ones and cost of powder) to redo my original calipers without removal and install of the ones that came out bad... Can't complain
Old May 4, 2015 | 07:47 AM
  #6662
Daddy Fat Sacs's Avatar
Daddy Fat Sacs
well beside the current break squeal issue...had a productive day yesterday
and going to try my luck in the HFC's area again....picked these brand new puppies up
Old May 4, 2015 | 08:22 AM
  #6663
AroundTheG37's Avatar
AroundTheG37
z1 cats?
Old May 4, 2015 | 08:36 AM
  #6664
Daddy Fat Sacs
z1 cats?
my bad.......FI RHFC
Old May 4, 2015 | 08:47 AM
  #6665
Again? What's the back story to that?
[edit] Nevermind. Right there at the top of your build thread. You were running Art Pipes for all of half a day before rasp made you give them up.
Old May 4, 2015 | 09:12 AM
  #6666
Lego_Maniac's Avatar
Lego_Maniac
They are squealing after the brake job? Looks like a fun day. The motive power bleeder is a great product
Old May 4, 2015 | 09:14 AM
  #6667
ChinkyChoy's Avatar
ChinkyChoy
just threw mine in and love them
got plenty of complements during the local meet I went to last Friday as well
Old May 4, 2015 | 09:17 AM
  #6668
Don't see any caliper grease in the shopping pile, hopefully that was used.
Old May 4, 2015 | 10:21 AM
  #6669
Lego_Maniac
The R-Spec pads had packets of caliper grease packaged with them. But yeah, cood call.
Old May 4, 2015 | 10:45 AM
  #6670
Daddy Fat Sacs
OK so I installed some StopTech brake pads on the wife's journey today, bleed the system and then bedded the pads. Problem I'm having is they squeak pretty good when coming to a stop. And yes I lubed the shims....anyone else have this problem or may have any recommendations??
sorry...yes I used some silicone brake grease on all moving parts, back of pads/shims....bedded properly...still squeaked afterwards.....not sure what it is...but drove me nuts all night thinking about it
Yes it is!!! 1st time using it and fell in love with it. Very simple to use and made the job 1000% easier and quicker. Def a great investment IMO
Old May 4, 2015 | 11:16 AM
  #6671
Lego_Maniac
Constant squeak?
Only on brake application?
Wifes car, so no sport/sliding calipers?
Old May 4, 2015 | 11:20 AM
  #6672
Daddy Fat Sacs
Constant squeak? no
Only on brake application? yes
Wifes car, so no sport/sliding calipers? correct - journey
answered above
Old May 4, 2015 | 01:01 PM
  #6673
Lego_Maniac
answered above
Can you tell which axle/side is squealing?
Rebedding them is probably the easiest potential solution without pulling things apart.
Old May 4, 2015 | 02:23 PM
  #6674
Daddy Fat Sacs
Yes it was the front axel and sounded like from the drivers side for sure and poss the pass. I talked to my wife a bit ago, she said she didnt hear anything this morning. So I'll check again when she gets home as mine and her hearing are a bit diff when it comes to cars
Worse case is I may try to bed them again to see if that helps as thats the easiest option, otherwise I'll just take everything off the fronts and re set everything. Good thing about the non sport is they are a BREEZE to open up. Takes me longer to take the wheel off then it does to change the pads. Thanks
Old May 4, 2015 | 02:54 PM
  #6675
nishfish871's Avatar
nishfish871
When I bedded the new pads and rotors I had smoke everywhere. It almost felt like it would catch on fire. Kept going while it was smoking to make sure I got that "glaze" on the rotor. My clothes and everything smelt like burnt brake pads.
Did you do the same?
