Sedan Chat Thread
I wonder if the diff brace can work in conjunction with this brace?
Interesting idea. I currently leverage a Cusco rear lower power brace (recommended by my suspension guy and CZP): https://conceptzperformance.com/cusco-rear-lower-power-brace-infiniti-g35-07-08-09-14-g37-15-q40-sedan-v36-08-13-g37-14-15-q60-coupe-cv36-288-492-r_p_18873.php
If you do install a diff brace, make sure you change your diff fluid out before doing the brace
https://www.myg37.com/forums/g37-sed...ml#post4314690
You have a side view? See the GK brace below.
I will call CZP tomorrow to see if they are aware of anyone running both braces in the same application. The Diff Brace being mounted directly to the subframe would seem to introduce more NVH, but others here are saying it doesn't.
The Bell diff brace brace doesn't appear to block the drain or fill plugs: https://www.bellraceworks.com/produc...ck-diff-covers
You could see if you get lucky at a Yard and find a fob with a physical key and take the door cylinder with it.
Outside of this I'm unsure of the process of re-keying a brand new door lock cylinder.
Wouldn't it be easier to just splice a cable onto the (already present) emergency release cable in the deck lid, snake it through to a hidden location, and then terminate it with a pull ring? It is not as if this setup would get daily usage. Or, just pop the trunk through the rear seat? I know it s not the easiest to do in the sedan as it is on the Coupe, but still doable in a emergency.
I am not 100% certain I understand the need...
ILM: use case is car locked, battery dead, blank cover over drivers side door handle key hole.
the idea would be to run a cable from the existing emergency pull bell-crank out the bottom of the trunk somewhere to a keyed cable pull. So the car would still need a key to unlock, but I could pop the trunk to get the car open.
If nothing else, there’s leftover but connected 4 gauge back there from a previous owners Amps.
edit: hopefully this is mooted by the battery tender and/or 1x weekly driving but I’m tired of paying $60 for the keyhole cover every time my battery dies, since I can never get them off unbroken.
Understood. Extreme of worst-case scenarios, but I can appreciate the logic.
If it were me I would just splice a cable onto the existing emergency release handle and run that through to a hidden location. Whichever method or kit you choose, you will still have to utilize the emergency release in the deck lid.
